Suspension problems
Old Jun 23, 2005 | 02:09 PM
SAC quattro's Avatar
Default Suspension problems
<center><img src="http://pictureposter.audiworld.com/72555/my_car_side_view2.jpg"></center><p>
Since I've had my car- about a year now- there has been a small squeak noise that comes from the front left suspension whenever I go over a bump.
In the past 2 or 3 days the noise has become much louderand more defined and is something that I've had to deal with whenever I take a turn (either direction), or go over any kind of pavement that isn't completely flat. It is especially noticeable when I'm going slowly and turning- say, into a parking spot, or my garage.
The car is going into my local shop tomorrow so my mechanic can listen/look at it and see what he thinks.
I searched for a while and found someone who a similar situation that he solved by spraying white lithium grease onto the bolts/joints that hold the suspension components together.
So I figured I would try it. I just sprayed all the joints that I could and took it for a drive and the creaking and squeaking were still there.
I had the tierod ends replaced in may so I'd assume it's not related to them. Let me know what you think- any help/advice would be greatly appreciated.
Thanks again.
Old Jun 23, 2005 | 02:18 PM
WJM's Avatar
WJM
Tech Guru
Default you try put a little bit of left foot brake on while going over the bumps to see if it goes away
brakes can cause the noises you describe...
side note why do you have a pic of Mark Bradford's ride below your sig?
Old Jun 23, 2005 | 02:22 PM
Default Ill give that a try- thanks
the pic below my sig rotates for the B5 FAQ- but apparently the link isn't working anymore for my sig. I'll have to fix it.
Old Jun 23, 2005 | 04:37 PM
typeITR's Avatar
New Member
Default I got that damn noise
but modify if by 100x and its 24/7
I'm basically in car hell
Old Jun 23, 2005 | 04:43 PM
pmark837's Avatar
Default i have that same thing too, on my right one, when i go over something rough, does'nt even need .....
to be bumps, just as i'm turning it'll squeak
Old Jun 23, 2005 | 04:47 PM
Skizsam's Avatar
Default Mine is in the shop for the same problem
I replaced all 4 shocks and still didn't go away.
So after speaking with the mechanic today he said it was the stabilizer link. I guess that was the fix. I will find out when I pick it up tomorrow.
Old Jun 23, 2005 | 04:52 PM
Urban Rally's Avatar
Default After installing my anti-roll bars myself, I get little squeaks when going over say
a speed bump, slow, very big/bouncy bumps. Some ppl were telling me thatI should have installed them while the wheels were under load. the rear I did not, but the fronts, I had to jack up the wheels to about normal ride height to actually fit them on... I am about to go under and try to figure out what making the noise (more like a grunt than a squeal noise, like a door squeak)
Old Jun 23, 2005 | 06:24 PM
TristanP's Avatar
Default To fix the FAQ link in your sig
See my sig.
 Michael S. Palmer
Old Jun 23, 2005 | 06:32 PM
DukeBoy27's Avatar
Member
Default At best, it's the stabilizer link, as skizsam pointed out, or the control arms
At worst, it's your steering rack.
I would say start by replacing out the cheapest parts first, like the tie-rod ends (which I see you have already done), and change out things when the noise is gone ---&gt; then report back what it was!!
I have the same issue, particularly on hot days.
Old Jun 23, 2005 | 06:37 PM
Joey T
Guest
Posts: n/a
Default Search broken again?
Ball joints, which in our cars are part of the control arms. Replace em all.
