Tail light wiring problem
Old Sep 28, 2006 | 12:34 PM
endlesswinterco's Avatar
New Member
Default Tail light wiring problem
hey guys, ive read the tech thread on converting the tails to the new 00-01 ones. i went to do it today, swapped the lights and went to swap the wires but i was unable to pull them out of there harness location. i used a flat head driver to push , pry, and did everything to get them out, but couldn't. is there a trick to it? please help
Old Sep 28, 2006 | 12:40 PM
NoNonsense's Avatar
Default you have to open the connector, then use a micro screw driver to pop them out.
if you don't open up the connector, they won't budge.
Old Sep 28, 2006 | 12:44 PM
New Member
Default Re: you have to open the connector, then use a micro screw driver to pop them out.
i did open the connector, and i used a small screwdriver and pushed on them from the connection side, and pulled the wire at the same time, i got nothing.
Old Sep 28, 2006 | 01:49 PM
NoNonsense's Avatar
Default if you look carefully at the inside of the connector, they are held in wedge-style....
you need to put the flat tip of a tiny screw driver at the right spot to get they "wedge" to lift and out comes the tip from the connector. Once you get one, the rest will be cake! ;-)
carlosd15
Q7 MK 1 Discussion
Mar 2, 2018 03:22 AM
Orlando 4000S
Jan 20, 2008 09:22 AM
Joey T
Aug 29, 2004 05:57 PM
Skibum the Original
Dec 7, 2002 11:54 PM
Evanem82
Jul 17, 2002 02:07 PM
