Tail lights
Old Aug 17, 1999 | 06:53 AM
Chris
Guest
Posts: n/a
Default Tail lights
I searched the forums,, but did not get a clear answer,,,Can you directly swap a 1.8T 1998 tailights with the amber blinker with a 1999 1.8T,,,
Old Aug 17, 1999 | 07:33 AM
MarkC
Guest
Posts: n/a
Default Re: Tail lights
1998 never had amber. You can directly swap the current European units, or you can put in the north american 1996 units by making some wiring modifications.
Zsolt
Guest
Posts: n/a
Default Be more specific...
If I am correct, in North America a new, all red taillight came in by 1998.5 models. Yet another change in 1999.5 models, where the turn signal and the back up light were swapped. As far as I know it still blinks red though.
I do not know if you may swap these w/o futher mod. The easiest way to find out is to post the color codes of the wires going into the tail light assembly 1-6 (there are total 6 of them numberred on the harness connector). Then someone with a 99.5 would do the same and if they are identical, the swap is direct. If not, then you have to swap your wires in the harness, which is some work, but doable (I just did it last weekend to move my brake lights to the upper positions of the taillight assembly). Email me if you need more info.
If you are to change from a 98.5 NA model to a 98.5 Euro, it IS a direct swap.
Old Aug 17, 1999 | 08:47 AM
George Jutras Jr.
Guest
Posts: n/a
Default Re: Be more specific...
I have a 98.5 and was wondering if I could make the rear fog lights come on with the center brake light and only have the bottom lights come on with the parking/head lights. I would think a connector pin swap would do the trick but I'm reluctant to try it. How did you do yours?
Spyder Auto
Vendor Showroom
Dec 10, 2011 02:20 AM
SpyderMR
Audi allroad
25
Aug 21, 2009 10:17 AM
PATRICK30
Oct 24, 2004 08:46 AM
Aqua Angel
May 13, 2003 08:08 AM
jyoteen
9
Oct 8, 2001 05:44 AM
