Temperature sensor
Old Nov 22, 1999 | 06:41 PM
Samantha
Guest
Posts: n/a
Default Temperature sensor
Hi,
Occasionally when I started my car (cold or warm), the temperature sensor may register -67F for a while between it can correctly displays the correct temperature. Last time, the sensor registered -67F and revert to the right temperature after the car has travelled about 5-7 km (this time the car was started warm).
Is this an indication of a faulty sensor? Please advise. Thanks.
Sam
1999 1.8T QS Tip
Old Nov 22, 1999 | 06:47 PM
pdw
Guest
Posts: n/a
Mines never done that. You should probably bring it to the dealer.
Old Nov 22, 1999 | 07:16 PM
K.L.
Guest
Posts: n/a
Mine does that too at startup, but very quickly will show the correct temp, like after 30 sec. or so
Old Nov 22, 1999 | 09:24 PM
Cameron
Guest
Posts: n/a
Default This is *not* a faulty sensor (much more)
this is an uncommon but recognized problems on four-cylinder turbo cars 1997 through 1999 not equipped with the trip computer feature.
The car will show -67, then -45, than the actual temperature, and sometimes stay at one of the "false" temperatures for some time. Also, if the car is stalled or put into neutral, the temperatuere display may go blank for a number of seconds.
No one knows what causes this problem, but this was a problem with my 1997 A4 1.8TQM and was annoying. It may also affect the A/C compressor, which works off the outside temperature reading, and hence your A/C compressor can be heard clicking on and off at idle.
My car had the sensor replaced two different times and had a replacement gauge cluster installed once, but the problem continued. One dealership suggested it may have something to do with the compressor or climate control logic. Email me for more information on this issue. There is presently no TSB.
Cameron
Audis...
1996 A4 2.8Q
1997 A4 (sold!)
1999 A4 1.8TQ
2000 TT 180Q (just arrived!)
2000 TT 225Q (April!)
Old Nov 23, 1999 | 06:52 AM
stevebrown
Guest
Posts: n/a
My 98.5 30V does it occasionally, too
Old Nov 23, 1999 | 09:32 AM
Chris B
Guest
Posts: n/a
Default Mine did something similiar.... (more)
I used to get false temperature readings, never as low as -65, but readings in the 60's during July in New Orleans. I went through a number of proposed fixes, including cleaning the connector, replacing the connector, and changing out some of the harness, but it was never fully fixed until a new sensor was installed. Since then, it has worked like a charm. I would have the dealer replace the temp. sensor.
Chris B
98.5 1.8T M
changoo
May 7, 2011 05:20 PM
mister pepper
Oct 1, 2010 11:22 AM
Edge
Q7 MK 1 Discussion
Jul 9, 2010 04:21 AM
Scott Evil
A4 (B7 Platform) Discussion
Aug 26, 2008 10:53 AM
Blackboard
Nov 3, 2006 09:57 AM
