Terrible Electrical Problem
Old Apr 18, 2006 | 02:03 PM
werksmini's Avatar
New Member
Default Terrible Electrical Problem
This is the last post I will make concerning this problem but I have made some new discoveries and would like to share them in the hopes that someone could help.
Symptoms:[list=1][*]Left the car for 3 weeks, battery dead.[*]Charged battery[*]Car wont start, turns over and beeps after ~10 seconds.[*]CEL wont turn on w/ ignition[*]Tried VAG-COM with two different systems, only airbags read[*]Tried two ecu's; GIAC and AMS[*]Jumped power relay to ecu and still no start.[/list=1]
So this is where I stand. The only thing I can think of is some sort of wire short in line to the ECU that would cause battery drain and the failure to start.
PS: fuel pump doesnt turn on
Im biting the dust tomorrow and taking it to the dealer if I dont get any leads. Thanks for all the help guys.
Old Apr 18, 2006 | 02:06 PM
TwentyValveB5+S4's Avatar
AudiWorld Expert
Default not related to your problem: to properly post pics on this forum
you want:
<img = "url of the image here" />
with 'src' in between 'img' and '='
essentially, the same as HTML
Old Apr 18, 2006 | 02:35 PM
picnicbob's Avatar
check fuse for fpump?
Old Apr 18, 2006 | 02:49 PM
JAFO's Avatar
Default there was the car parked: inside or outside?.....
you may have a rodent problem. i'd look for signs of a nest in the car and chewed wires.
Old Apr 18, 2006 | 02:53 PM
werksmini's Avatar
New Member
Default Re: there was the car parked: inside or outside?.....
outside, I dont think its rodents though. I also dont think its the fuel pump because there are much bigger problems. I wouldnt be suprised if a ton of other systems arent working. When I VAG-COMed it it only scanned the airbag. All of the other systems didnt work.
Old Apr 18, 2006 | 04:18 PM
ImAwesome's Avatar
Senior Member
Default wasco1989 just went through something similar.. it was a frayed wire
from fuse number.. 7? iirc... take out the knee bolster.. and takeout the fuse panel... take a look at all the wires. Same thing after he jumped his car... i think you have the same thing
Old Apr 18, 2006 | 04:47 PM
wasco1989's Avatar
first of all what year is your car? because something similar happened to me
Old Apr 18, 2006 | 05:19 PM
ImAwesome's Avatar
Senior Member
looks like a 2000 or 2001
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 19, 2006 | 12:03 AM
datsea's Avatar
New Member
How old is the battery? Have you tried a jumpstart?
Campbell420
Audi A3 / S3 / RS 3
Mar 15, 2014 10:10 AM
BaMmAsS
Audi Original "S" Cars
Mar 12, 2013 06:21 PM
coupe d'mike
Nov 30, 2005 06:40 AM
liltracy
Oct 8, 2004 03:57 PM
Dennis H.
Nov 23, 2001 07:41 AM
