Testing plug wires - can I do this with a multimeter?
- Pull the ignition wires from the spark plugs.
- In order to perform a resistance measurement, connect multimeter between both spark plug connectors of the respective ignition circuit to be checked. i.e., resistance between coil and 2 wires.
ATQ Specification: each 16 to 27 kOhm
AHA Specification: each 18 to 25 kOhm
- If the specified values are not reached, disconnect ignition wires from ignition coils and perform a separate resistance measurement at the ignition wires and at the ignition coils.
- For ignition coil, connect multimeter between both ignition wire connectors of the ignition coil to be checked.
Specification for both AHA and ATQ: 8 to 14 kOhm
- For each ignition wire, connect multimeter between both ignition wire connectors of the ignition wire to be checked.
ATQ Specification: 3 to 7 kOhm
AHA Specification: 4 to 6 kOhm
- Replace faulty components if the specified values are not reached again.
IE I remove all the wires from plugs, and measure resistance between, say, wire 1 and wire 2? 1-3, 1-4, 1-5, 1-6 and repeat with 2, 3, 4, 5?
Which piece is the ignition coil on a 2.8?
Like Kris says, there are actually 3 coils, each feeding a pair of wires. You'll have to measure resistance from the tip of one wire to the tip of the corresponding wire. If that whole combination is out of range, then break it down into individual wires and/or coils.
