throttle adaptation problem...
Old Nov 4, 2003 | 12:32 PM
DrewP's Avatar
New Member
Default throttle adaptation problem...
i have a 99.5 non-dbw 1.8t in limp mode which has been giving 17953 P1545 Throttle Pos.Contr Malfunction after i had switched the battery. i tried doing an adaptation with my vag-com, but when i go to measuring block 098 or 060, the box for the adaptation says error on it. the other boxes say this...
4.4 throttle valve pot voltage
3.72 throttle drive pot voltage
0 throttle valve angle
29 throttle drive angle
measured power voltages on pins 3 & 4 on the connector to the throttle body is in spec.
and i've tried another throttle body from a junk yard and i got the same results. any experts out there with some input? thanks.
Old Nov 4, 2003 | 12:35 PM
Stratocaster1422's Avatar
Member
Default did you try unhooking the battery for a bit, hooking it back up and do the TBA with the ignition....
and not the VAG?
Old Nov 4, 2003 | 12:37 PM
DrewP's Avatar
New Member
i've tried that method first with no success
Old Nov 4, 2003 | 06:15 PM
Audi2ptzero's Avatar
Elder Member
Did you try putting in a stock ECU and see if the issue changes?
Ynnekdude
Oct 3, 2012 09:54 AM
FischerWausau
A4 (B8 Platform) Discussion
Apr 12, 2011 06:49 AM
Henka_E
May 22, 2006 10:03 AM
AudiForYou's 2.7T
VAG-COM Discussion
Oct 6, 2004 02:18 PM
Lucas
Feb 10, 1999 04:29 PM
