Tip vs. Man
Old May 7, 2001 | 06:31 PM
  #11
AVANTedge's Avatar
Junior Member
Re: tip - sticks are for ego - tips are for drivers LIKE F1 racers
Old May 7, 2001 | 06:35 PM
  #12
PSS  //  Raj's Avatar
Default I do agree with you on that point actually. If you promise to only drive in tip mode, then it's ok.
My only regret is that I can't mod as much, since the transmission can't handle the same torque levels. That's a real pisser!!
Old May 7, 2001 | 06:38 PM
  #13
Parrothead's Avatar
New Member
Default An auto is fine for a normally aspirated engine (2.8), but with a turbo, you'd probably
want a manual if you'll ever want to accelerate hard from a stop.
Hey, are you in KY? Me too. Not too many others on this board from this region. Where abouts?
Old May 7, 2001 | 06:39 PM
  #14
markbradford's Avatar
Rest In Peace
Default LOL! Oh how misinformed you are.............
Tiptronic is NOT an F1 style tranny.
Tiptronic is a marketing tool. It is simply a catchy interface for the old method of using D,3, 2,1. Now instead of moving the lever down a notch sequentially, you tap it front or back. Whoopee. It's still just a plain *** automatic.
Old May 7, 2001 | 06:43 PM
  #15
Rest In Peace
Default Elaboration............
F1 cars have servo-assisted clutches. Auto trannies like the Tip have Torque Converters.
Therefore, I suppose the real poseurs are the Tip drivers. Sorry.
Old May 7, 2001 | 06:44 PM
  #16
Parrothead's Avatar
New Member
Default Aren't F1 trannys (along with the Ferrari F1 semi-auto) really manual transmissions
with a hydraulically actuated clutch? Seems like I read that somewhere.
Old May 7, 2001 | 06:46 PM
  #17
Parrothead's Avatar
New Member
Damn you're too fast. And my dial-up connection is too slow!!
  #18
Evan (Vogon)'s Avatar
Default Tip is actually different that D,3,2,1
it stays in the gear you select -- if you put an auto in 3, it will still go though 1,2 to get to 3.. it only limits the top
 Michael S. Palmer
  #19
eMKay (BFLO)'s Avatar
AudiWorld Uber User
Yes, but the clutch is operated by a solenoid or servo
Old May 7, 2001 | 06:47 PM
  #20
James R.'s Avatar
Default Yep dry plate...it's not anything like an automatic...it's a normal clutch with
a computer that monitors road speed...engine speed...shaft speeds...etc using all this it does a better job with the clutch than you could ever dream of. I heard some of them even will blip the throttle for you on the downshift...that's just sick, I want one ;-)
Regards,
James R.
