traction control
Old Feb 2, 2004 | 08:08 AM
justinr66's Avatar
New Member
Default traction control
does anybody know how to turn off traction control on a 2000 1.8t quattro a4. thanx
Old Feb 2, 2004 | 08:14 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default why would you want to do that? Oh, and there is no way...
mainly, I didn't realize that any quattros had traction control specifically...
Old Feb 2, 2004 | 08:17 AM
Silver Streakin''s Avatar
Member
push the button marked ESP.
Old Feb 2, 2004 | 08:19 AM
Head Cat Herder
25 Year Member
Default Lay wheels? WTH is that? With a quattro, the rear axle is mechanically attached to the front...
there is no way to turn that off. when you dump the clutch, something has to give, the clutch is the weakest link..
Old Feb 2, 2004 | 08:20 AM
justinr66's Avatar
New Member
Default Re: Lay wheels? WTH is that? With a quattro, the rear axle is mechanically attached to the front...
what are you talkin about you could lay a wheel with a quattro. all the wheels would spin
Old Feb 2, 2004 | 08:23 AM
Head Cat Herder
25 Year Member
Default Yeah, if you had 300hp... you'd still more than likely roast the stock clutch..
you would have to be on a very low grip surface as well.
There is no traction control other than ESP and EDL on any Audi with quattro. You are just not putting enough power down to spin the tires.
Old Feb 2, 2004 | 08:24 AM
justinr66's Avatar
New Member
Default Re: Yeah, if you had 300hp... you'd still more than likely roast the stock clutch..
man, ive talked to audi guys, there is traction control and what it does is not allow the clutch to let the car get into gear. on newer models it can be turned off in the car and there is somway to do it. THE quatrro COULD lay a wheel
Old Feb 2, 2004 | 08:26 AM
Head Cat Herder
25 Year Member
The 'Audi guys' you refer to need to go back to school.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 2, 2004 | 08:33 AM
audiski's Avatar
Member
Default Actually, Kris is one of the most knowledgeable members of this forum
you need to calm the hell down.
Old Feb 2, 2004 | 08:36 AM
Matt2.8.. Evoluzione's Avatar
Member
vote to ban. unacceptable conduct.
