Transmission Problem
Old Jun 22, 2008 | 05:14 PM
Lauda81's Avatar
Default Transmission Problem
I just finished installing the transmission and its worse than before now when I put in D it wont even engage if you rev the engine it does not kick in I scanned 02 and came up with the code 00297 transmission speed sensor G38 No Signal, could this block the transmission from doing its job? how can I fix it or what should I do???
Any help is highly appreciated!!!
Old Jun 22, 2008 | 08:02 PM
audinutt's Avatar
25 Year Member
Default It could, what happened and where did you get the transmission?
change the torque converter too?
-richard
Old Jun 22, 2008 | 08:36 PM
Lauda81's Avatar
Default Re: It could, what happened and where did you get the transmission?
at force 5 someone refer me from this forum...
Old Jun 22, 2008 | 08:41 PM
Lauda81's Avatar
force 5 someone referd me from this forum
Old Jun 22, 2008 | 08:57 PM
Lauda81's Avatar
Default it came with the tranny but it may be shout duno it doesnt move at all
little bit on reverse at first but now nothing...
Old Jun 22, 2008 | 11:19 PM
audinutt's Avatar
25 Year Member
Did you check your fluid level and verify the rpm sensor is installed correctly?
Old Jun 22, 2008 | 11:39 PM
lberisha's Avatar
New Member
Default well it doesnt move at all because G38 is the gear speed sensor
it thinks the car is off because it does not realize the gears are moving in order to engage. so check the G38 sensor and can you post the full error code or thats all there is. like is it intermitent or what
Old Jun 23, 2008 | 12:03 AM
Lauda81's Avatar
Default here it is...
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D05
Coding: 06251
Shop #: WSC 00012
No fault code found.
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 BQ
Component: AG5 01V 2.8l5V USA 8511
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
00297 - Gearbox Speed Sensor (G38)
03-00 - No Signal
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D00
Coding: 0273004284
Shop #: BB 24334
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04162
Shop #: WSC 06335
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 930 QX
Component: B5-KOMBIINSTR. VDO D18
Coding: 07242
Shop #: WSC 42009
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump D10
Coding: 16140
Shop #: WSC 06335
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 A
Component: Radio D02
Coding: 00117
Shop #: WSC 06335
End -------------------------------------------------
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 23, 2008 | 04:20 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Have you checked the fluid level?
Old Jun 23, 2008 | 08:49 AM
lberisha's Avatar
New Member
Default Usually if it says "no signal" its a sign that sensor either disconnected or broken
Never rally had to find that sensor, locate it and inspect it.
