transmission trouble
no probs at all, car works great, wife starts up car after a cold cold night, car starts and puts it in gear ,goes down the driveway, goes to pull out no forward in any gear!!! but has reverse, she left car , i got home and checked , it was not in limp mode, i checked the tcm under the seat for water, DRY DRY DRY. hooked vag-com to pull codes,cannot read engine codes, and had a transmission brake light code, i plugge in my obdII reader and can read engine codes, had some evap codes. i unplugged the tcm and the car will pull itself around yard, plug back in and will not even pull itself over 1 1/2 hoist center. read that the multifuction swith or TR switch is common, replaced with another and still no forward. when i hook up vag-com i can read the auto trans codes and block values,when car is not running, when i start the car it loses communacation with the tran control module, i cannot beleive that a tranny would fail without any slippage , and just sitting over night, so im still thinking it a electrical issue,,, any know wires or grounds or plugs the are common for problems? thanks in advance!!! hope o get this sorted out soon!!
so i was on the lookout for another transmission, and found a 1999 a6 2.8 quattro wagon that needs 2 upperballjoints, 2 outer tie rods and major oil leak at the front (guess crank seal) im getting this for $500 , the timing belt, water pump,pulleys and idlers where replaced last year about 20,000 kms when they replaced the engine with a salvage yard engine that only had 120,000kms on it, im thinking of fixing the a6 and using the a4 for parts, BUT the wife hates the beige interior in the a6 and the a4 has black, i think im gonna win, now the a6 ? how do i now if it is an avant? ive been reading that avant means that it is a wagon, which this is.. guess i'll try and keeep this updated as i go
The car does move in D,4,3,2....but when you go forward a bit, the car seems to downshift harshly and stalls.
I switched out the multifunction switch, and put another TCM on the car and there is still no change. Im wondering if a vag com is needed to clear any hidden codes??? I have a cheap Actron code reader, but it is not showing any codes, and the car is not in limp mode. I can make it go into limp mode by disconnecting the multi switch on the side of the trans. It does not show any codes on my Actron scanner, but when I hit erase codes anyway, the limp home mode will disappear.
I tried to check the fluid today, but I do not have 4 jack stands to elevate the car evenly....I lifted driver side to get to the filler plug, and with it elevated with its nose up, when I took out the filler plug, not one drop came out...which im assuming means its low...I tried to fill it as best as I could, but Im afraid I did not get enough in...i will have to retry using another method to get under car to do this right.
I do have a vag com cable on its way so perhaps this will help me see exactly what is going on. Im assuming with the lite version (free) you can still see codes and clear them?
