Tree Sap Solution
Old Jul 26, 1999 | 05:05 AM
JimV
Guest
Posts: n/a
Default Tree Sap Solution
Finally found a good solution for getting tree sap off my car and I thought I would share my triumph.<br>First, don't wait to get it off. It will ruin your paint.<p>Take a plastic credit card and scrape the top portion of the sap off. I've been told that Ice works as well.<p>Next, Get some rubbing alcohol and start rubbing. This takes off just about all the sap.<p>Then I used some clay bar and quick detailer to get the finer parts off.<p>Wax the car.<p>This works really really well. Im happy with the results.
Old Jul 26, 1999 | 05:46 AM
ALD
Guest
Posts: n/a
Default Rubbing alcohol and cars...
DON'T USE RUBBING ALCOHOL ON CAR PAINT AGAIN!!! Rubbing Alcohol eats through car paint, no joke. In college a girl used it on her car and took the paint off of the driver door, and she was wondering why as she started rubbing why blue paint was appearing on the cotten ball. Rubbing Alcohol brakes down the paints clear coat as well as the paint. It is like using nail polish remover on your car, you get the exact same effect. You have already done some damage to your paint because of that. <br>If you want to get tree sap off a car, use gasoline. Pour a little bit on a rag, and rub gently, and then immedialely wash the car after, and wax. This is much safer for your car's paint then using rubbing alcohol.<br>And also, don't use a credit car either, because it can scratch the surface, if you goof. <br>
Old Jul 26, 1999 | 06:52 AM
Shabbis
Guest
Posts: n/a
WD-40 might work (not sure on this though)...
Old Jul 26, 1999 | 07:21 AM
Lewis
Guest
Posts: n/a
GooGone works
Allraodgone
Q5/SQ5 MKI (8R) Discussion
Jul 5, 2010 04:46 AM
SleepDrS4
May 7, 2006 06:54 PM
adminisTerTurbo
Jun 10, 2005 06:55 AM
Banter
Auto Detailing Discussion
Oct 1, 2001 02:56 PM
Doug G
Apr 21, 1999 11:39 AM
