Trouble Code Nightmare
Old Jul 18, 2007 | 04:15 PM
Nicholasbeast's Avatar
Default Trouble Code Nightmare
Well my 96 A4 is definitely not preforming like it should. Just pulled 8 trouble codes including:
-P0102 mass air flow sensor circuit, low input
-P0116 engine coolant temp. circuit range,
-0401 Exhaust gas recirculation flow insufficient
-P0161 oxygen sensor heater circuit malfunction
(Post-Converter sensor, bank 2)
-P1393,1394,1395 Ignition coil power output stage 1,2,3 electrical malfunction
-P1509 idle air control circuit malfunction
So you see I'm a little lost. Last year about thethis time I had 2 code EGR recirculation insuff. and IAC circuit. Cleaned the EGR, reset the ECU, but the engine light still illuminated. I just did a timing belt about 800mi ago, so hopefully I didn't screw something up. Also when the car is idling the needle bounces roughly 50 rpm also on some occasions the car almost stalls to where the lights on the instrument cluster turn on. I thought it might be a vacuum leak, but I don't know for sure. If anyone know how to diagnosis or point me in the right direction in fixing my slowly dieing car it would be greatly appreciated. -Nick East
Old Jul 18, 2007 | 04:31 PM
n0yxl's Avatar
Wow that's alot of codes....do they all come right back after you clear them?
Old Jul 18, 2007 | 04:42 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default My guess is a wiring harness got fubar'd or wasn't plugged back in properly.
All of this appeared at the same time?
Old Jul 19, 2007 | 02:48 PM
Default Re: Wow that's alot of codes....do they all come right back after you clear them?
yeah I cleared the codes after I did the timing belt...it looks like I'm up **** creek without a paddle
Colonel Bogey
19
Dec 4, 2012 02:08 PM
AudiSport4000
10
Aug 6, 2007 08:44 PM
kday
Audi 100 / A6 (C4 Platform)
Jan 13, 2007 08:07 AM
A4wheelin
Jun 22, 2006 10:01 AM
JMSIV
Audi allroad
Nov 18, 2005 02:45 AM
