Turbo timer install ques
"Now locate the 14ga red wire which comes up from the ignition switch. This is your 12 Volt constant which is used to power the turbo timer. You may become confused, as there are several red wires in that bundle. If you like you can remove the upper trim pieces on the steering column and loosen the lower piece as much as possible (Allen screw underneath lock lever, and two Phillips screws up inside the holes on the bottom side as well). With all of these things loose you can just barely look at the back of the key switch. You'll see 5 positions on the switch and a total of 6 wires; one of the switch positions is shared with another wire for the Load Reduction Relay just FYI. Anyhow you should locate the red 14ga wire which comes out of the ignition switch (you can pull on wires up top and see if they're moving below); this is a good indication that you've got the wire you want. "
since you have a volt meter, why not just test for the wire that goes live when you turn the key to the on position?
