Turbo timer question.....
Old Sep 26, 2001 | 10:02 AM
Norcalguy's Avatar
Junior Member
Default Turbo timer question.....
So is there an easier way of wiring it up I don't feel to comforatable about
pulling out the instrument cluster to get to the main harness then splicing into
that any help would be great.
-Norcalguy
Old Sep 26, 2001 | 10:05 AM
FourRings's Avatar
Default Only other option is ripping into the wiring on the bottom of the steering column....
JamesR's FAQ is the best route IMO. One thing though. The wire that you cut that comes off the fuse block can be tapped instead of cut so long as you pull the fuse. Beats cutting a wire.
Old Sep 26, 2001 | 10:06 AM
Speedy's Avatar
Default We tapped the wires on my TT into...
...a wiring plug that snaps into the steering column on the left side of the steering wheel. It works just fine and all you have to remove is the shroud around the steering column.
Cheers,
Old Sep 26, 2001 | 10:08 AM
Evan (Vogon)'s Avatar
Default what they said
but really.. pulling the cluster off is certainly the easiest part.. two screws.. thats it
Old Sep 26, 2001 | 10:13 AM
Sal R.'s Avatar
Default Well not quite THAT simple...
...you have to unhook three connectors in the back. They unsnap and pull free. Easy.
Old Sep 26, 2001 | 10:15 AM
Norcalguy's Avatar
Junior Member
Default Ok guys thanks I think I will do the install this weekend or next anyone know....
the cheapest place to get a Greddy Turbo timer III???
Thanks,
Norcalguy
Old Sep 26, 2001 | 10:16 AM
Sal R.'s Avatar
Default FAQ...
FYI - I got mine used for $50.<ul><li><a href="https://forums.audiworld.com/a4/msgs/615688.phtml">See Turbo Timer...</a></li></ul>
Old Sep 26, 2001 | 10:19 AM
Default this might build some confidence..
<ul><li><a href="http://www.performanceix.com/how-to/electronics/audi_a4_turbo_timer/audi_a4_turbo_timer.asp">http://www.performanceix.com/how-to/electronics/audi_a4_turbo_timer/audi_a4_turbo_timer.asp</a</li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 26, 2001 | 10:24 AM
Norcalguy's Avatar
Junior Member
Default Excellent Faq confidence restored I'll do it next weekend this weekend if I get
the timer in time.
THanks,
-Norcalguy
Old Sep 26, 2001 | 10:28 AM
Norcalguy's Avatar
Junior Member
Default Thanks Sal I'll give them a call...
-Norcalguy
