UPDATE to my problem, not a solution!!!
Old Oct 20, 1998 | 04:09 PM
KeremD
Guest
Posts: n/a
Default UPDATE to my problem, not a solution!!!
Those who were here 2 weeks ago will remember that I had a noise coming from my engine area after I chipped my car. There were recommendations made but the noise gone away 2 days later. I thought it was a turbo problem, because it was sounding like a metallic noise when I tried full throttle at low speeds in high gears. I heard the same noise again today, when I checked it. ( I was suspicious since the first incident that my car had a problem). I stopped the car and got out and closed the door. I heard the same metallic noise like 2 metals are contacting. I kicked several times my left, front tire and the noise was there. What I think is, vibrations are causing some parts to touch each other and make the noise. What do you think?<br>What can be loosen or broken there?<br>
Old Oct 20, 1998 | 11:46 PM
Randy Welch
Guest
Posts: n/a
Default Re: UPDATE to my problem, not a solution!!!
Do you hear a metallic noise when you shut the door occasionally?<p>Perhaps the screws holding the shield up have un screwed. It's pretty obvious if you look under the car. <p>-randy<br>
bigmacunion
Oct 26, 2004 06:17 PM
Justin517
Aug 5, 2004 08:01 AM
MatthewZ
Oct 20, 2001 07:00 PM
Les' Red TTR
Nov 17, 2000 11:11 PM
Craigito
Feb 9, 2000 10:29 AM
