UPDATE on need engine help
IS this only happening on idle situations? Maybe try cleaning the idle control valve.
You could also sqish the MAFS in some denatured alcohol to make sure it's clean. (BE VERY CAREFUL - DO NOT TOUCH THE SENSOR AT ALL - I JUST BROKE MINE LAST WEEK AND IT'S A $380 PART TO REPLACE , LUCKILY I SCORED ONE OFF OF A WRECKED A4 FOR $80)
You could check the plugs to make sure they're tight and not fouled.
Other than that, I'm not sure. I'd definitely call Hoppen in the morning. On probably an unrelated note, have you replaced your timing belt yet?
Timing belt was done around 65K.
Thanks for the info Mark.
