V1 question
Old Nov 6, 1998 | 05:56 AM
David P
Guest
Posts: n/a
Default V1 question
I just ordered a V1 + concealed display this morning. Expensive birthday present... Does anyone else out there also have the concealed display? Where did you put it? I was wondering if it fits inside of the pop out ashtray if you remove the insert. It measures 1x2.5x1.2 inches.<p>David
Old Nov 6, 1998 | 11:01 AM
DaveD
Guest
Posts: n/a
Default Re: V1 question
I velcroed mine to the top of the steering column, where it is easy to see but partially blocks the outside temp display. I look at mine fairly often, so like to have it close to my field of view. <p> - DaveD
Old Nov 6, 1998 | 11:43 AM
Josh L.
Guest
Posts: n/a
Default Re: Actually...
I just use the normal V1 display and "hardwire" it to my fuse box. The display is high up (upper left hand corner of windshield), but easy to detach (just unplug RJ11 and put under seat or in trunk). The concealed kit seemed like a good idea until I realized that I'd need to have the V1 mounted somewhere to look forward and back anyway...<p>-josh<br>98.5 2.8qms
Old Nov 6, 1998 | 12:54 PM
Jay Cole
Guest
Posts: n/a
Default best price/mailorder for v1
<br>need a v1, can i expect a discount price<br>off the $399 list?<p>also, is the v1 available w/o the laser<br>detection?<p>e-mail me to save BW. deluxe@usa.net<p>thx!<br>
Old Nov 6, 1998 | 01:34 PM
DaveD
Guest
Posts: n/a
For routine driving, I have mine on the dash covered with a small dark gray towel. It blends in pretty well with the dash. People can see something's there, but it isn't obvious what it is. I put it in the corner of the dash close to the driver side A-pillar. I've had good luck with it there, and the back antenna seems to work Ok. I don't normally see any laser in my routine driving. I assume the towel hurts laser detection, although with my old detector was able to detect laser thru a towel. For hi risk driving, I have a second power cord run up to the passenger side visor, and mount it there using the visor clip. With the remote display attached, the main unit display is off. This makes it a bit less noticeable, especially at nite.<p>Dave<br>98.5 2.8qms
Old Nov 6, 1998 | 03:15 PM
Big O
Guest
Posts: n/a
Nope . . direct only! Used to get w/o Laser (like mine, 1/2&quot; thinner) for $329, no longer available
mweber_delmar
RS4 (B7 Platform) Discussion
Feb 5, 2009 12:30 PM
BmwSlayer is rising
Dec 26, 2004 02:11 PM
RostyVyg
11
Mar 14, 2004 06:44 AM
grizwick
Jun 12, 2002 01:42 PM
Jurgen
Nov 4, 2000 12:22 PM
