VAG code explanations?
Old Jan 20, 2004 | 09:18 AM
TKNorCal's Avatar
New Member
Default VAG code explanations?
Hey everyone. I'm new to the Bay Area so hopefully I'll be able to get in on some of the events. But for now, to anyone that might be able to help, I recently had these codes pulled from my A4. The brake/ABS lights have been coming on shortly after driving away from my house...
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 Q
Component: AG5 01V 2.8l5V USA D03
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Coding: 0265109043
Shop #: BB 34171
1 Fault Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
35-10 - - - Intermittent
This started happening after the wheel bearing and abs sensor were replaced in the rear passenger side. Has anyone had this problem and if so, what have you done to fix it? Thanks in advance, and thanks to Leonard for helping me out with this.
Old Jan 20, 2004 | 09:19 AM
RNO.Audi's Avatar
Senior Member
Default They might know alittle more here...
<ul><li><a href="https://forums.audiworld.com/vag/">VAG fourm</a></li></ul>
Old Jan 20, 2004 | 10:19 AM
Stratocaster1422's Avatar
Member
do you clear them and they keep coming back?
Old Jan 20, 2004 | 10:42 AM
TKNorCal's Avatar
New Member
yes
TKNorCal's Avatar
New Member
thanks
Old Jan 20, 2004 | 10:50 AM
Member
Default try unplugging and plugging the ABS sensor back in...
maybe it didn't make a full connection or it came loose after it was replace.
N_Jay
Nov 7, 2017 02:50 PM
1st car in my name
Oct 28, 2008 08:04 PM
a4avant99
Oct 14, 2005 12:12 PM
slimshady
Apr 14, 2004 11:47 AM
TKNorCal
VAG-COM Discussion
Jan 20, 2004 06:01 PM
