VAG Error
Old Feb 15, 2001 | 09:01 PM
Trip_McNeely's Avatar
New Member
Default VAG Error
<center><img src="http://pictureposter.audiworld.com/1942/dtc.jpg"></center><p>My Check Engine light came on a couple weeks ago but went out after 4 days of driving. My friend ran his vag tool on my car and found these fault codes. Should I panic?
Old Feb 15, 2001 | 09:19 PM
James R.'s Avatar
You should go in...possibly a bad ignition coil...or a faulty injector...bad plug on cyl #2
Old Feb 15, 2001 | 09:54 PM
®ob's Avatar
Didn't someones ignition acclerator (the thing on the intake) cause this once?
Old Feb 16, 2001 | 03:02 AM
juliem's Avatar
Default Did you previously start the car, drive/idle for just a minute or two and shut down?
If so, don't worry. You had a temporary flooded condition from the cold start extra fuel enrichment.
Otherwise, as suggested - check it out at the dealer..
Old Feb 16, 2001 | 06:06 AM
xr4tic's Avatar
Default It's intermittent....
Try clearing the codes and see if they come back. Those codes could have been there for quite a while.
Old Feb 16, 2001 | 08:08 AM
carace's Avatar
New Member
Default Re: VAG Error
You could swap coils to check them and worst case it is not that difficult to swap injectors. You would be able to see if the problem moves with either piece.
EdyJun
Oct 15, 2004 01:42 AM
AudiS4inCT
Jul 31, 2003 07:40 PM
chisilvertip
Chicago Discussion
Oct 18, 2002 12:20 PM
djnelsen
Aug 4, 2001 04:46 AM
djnelsen
Aug 3, 2001 09:31 AM
