VCG Problem
First, check that the electrical connector on the bottom of the coolant bottle is connected frimly and correctly. It only goes on one way.Check the wires for any problem. The procedure to let the air out of the system is in this forum.Check for it or google for it. This will bleed the air out properly. If the car is not over heating this should do it.
First, check that the electrical connector on the bottom of the coolant bottle is connected firmly and correctly. It only goes on one way.Check the wires for any problems. The procedure to let the air out of the system is in this forum.Check for it or google for it. This will bleed the air out properly. If the car is not over heating this should do it.
