Weird Noises...
Old Apr 6, 2001 | 05:25 AM
Ben/A.W.E.'s Avatar
Member
Default Weird Noises...
Okay.. I've been hearing so weird noises in my car. When the weather was cold, my turbo used to whine or whistle when I first started driving. Now the weather has warmed up and it doesn't stop... It just whines for the entire drive. Is something wrong with the turbo?
Second, my car used to be almost silent at idle. At lights and stuff, people would ask me if I stalled cause it was so quiet. Now there is this tapping noise coming from the engine. Some of my friends with older cars have this problem, but I don't understand why I would. What is it?
Old Apr 6, 2001 | 05:36 AM
Mr. Mom's Avatar
AudiWorld Expert
Default Open the hood, is the tapping coming from above the airbox?
or from the valves?As the weather is getting warmer, the MAS (I believe) ticks like crazy. This is normal.
If its the valves, bring it to the dealer.
HTH,
Peter
Old Apr 6, 2001 | 05:37 AM
Ben/A.W.E.'s Avatar
Member
What's a MAS?
Old Apr 6, 2001 | 05:41 AM
markbradford's Avatar
Rest In Peace
Mass air sensor.
Old Apr 6, 2001 | 05:48 AM
EdP's Avatar
EdP
AudiWorld Uber User
Default It's the secondary air pump - emissions equipment on the 2k's
I have a 2k also. It's normal.
Old Apr 6, 2001 | 05:49 AM
Ben/A.W.E.'s Avatar
Member
I would have to say that the clicking is coming from the engine... =(
Old Apr 6, 2001 | 06:20 AM
Mr. Mom's Avatar
AudiWorld Expert
Default If that's the case, you may have damaged a hydraulic lifter.
Just to be sure, get the engine hot and listen to where the sound is coming from. This will give you a better idea of what may be wrong.
If its just a slight tapping sound from the lifters, don't worry. If its gets really noisey and you think its fron the bottom end, you most likely spun a bearing by over reving your engine, although not likely in a 1.8 T though as the bottom end is built for abuse.
Good luck, if you check it out, let us know more as there will be someone here who can help (AW is great, despite all the whining here lately),
Peter
Old Apr 6, 2001 | 06:47 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default Disagree Ed.
That secondary air pump makes the car sound like an old VW. It's not consistent with the noises she mentions. Tapping sounds like lifters, and the increased whine could be from more boost in the warmer temperatures.
Audigirl, when the weather is cold, the ECU will dial back the boost. When the temps reach about 60, I think the ECU will dial up a larger amount of boost. This could result in a louder turbo whine. It's hard to judge, but do you notice the car pulling harder?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 6, 2001 | 06:56 AM
James R.'s Avatar
The ticker on top of the Air Box is the Evap Canister Purge Valve FYI
Old Apr 6, 2001 | 07:00 AM
WJM's Avatar
WJM
Tech Guru
Default sounds like she is describing valve tapping to me!
I had this happen for the first time the other day...
I drove around for a bit and it went away...
go see your dealer
