Weird running problem...
Old Mar 19, 2008 | 10:00 AM
Nkugs90's Avatar
Default Weird running problem...
So the last couple of days my car has been running very funny. After it warms up I would notice a very strong hesitation, almost like a backfire but not as severe. It almost seemed like it could have been a slipping clutch which is a job that I was hoping I would not have to do in the next couple of months. The car was throwing no codes which made me think even more that it was a clutch related issue. Well since the car seemed very much like it was misfiring I decided to check the spark plugs to see if there was a crack in one of them or something silly like that. I pulled the first 2 and they looked fine. When I got to the second 2 plugs the gap was completely gone. The point on the gap was basically rounded off on the back 2 spark plugs. Here is a pic of what all of the plugs looked like upon removal. After throwing in a new set the car ran like a dream again. I have just over 30,000 miles on the set pictured which is about the required change interval but they still seem a little bit more worn than they should be. Just something to keep in mind in case any of you are experiencing similar problems.
<img src="http://i52.photobucket.com/albums/g38/Nkugs90/sparkplugs.jpg">
<img src="http://i52.photobucket.com/albums/g38/Nkugs90/sparkplugs001.jpg">
Old Mar 19, 2008 | 11:14 AM
n0yxl's Avatar
Missing electrodes can't be good. Something foreign must have been bouncing around in there.
Old Mar 19, 2008 | 11:32 AM
Nkugs90's Avatar
Default Its a possibility...
But I have seen what a plug looks like when a foreign object is bouncing around in a motor and usually the end of the plug looks completely destroyed. That would be a pretty lucky swipe if only the electrode was gone and the arm survived.
Old Mar 19, 2008 | 12:14 PM
@wesome's Avatar
coppers = every oil change
Old Mar 19, 2008 | 12:15 PM
@wesome's Avatar
definitely from wear/tear
Old Mar 19, 2008 | 12:30 PM
A400's Avatar
I cant see that, would have done something to the arm. Did car run OK after changing plugs?
Old Mar 19, 2008 | 12:51 PM
Nkugs90's Avatar
Yeah, the car runs awesome with new plugs.
Old Mar 19, 2008 | 01:15 PM
MonkeyLover's Avatar
Member
Default Those are platinums...but I still wouldn't run them for 30k miles.
I'd ask the platinum guys how long they run them. I run coppers and swap them every oil change. They're pretty cheap so why wouldn't you?
 Michael S. Palmer
Old Mar 19, 2008 | 01:17 PM
Member
2nd. Just exceeded their life span.
Old Mar 19, 2008 | 02:31 PM
duburban's Avatar
New Member
Default Re: Weird running problem...
Just read your specs, that avant must handle nice! I have a 2.8 avant with sport that has room for improvement.
