Wet NOS kit question....?????
Old Mar 14, 2002 | 08:48 PM
crazydrvr20's Avatar
New Member
Default Wet NOS kit question....?????
i have a '98 1.8T and i'm in the process of putting a 50 shot wet kit on it, now where on the damn motor do i connect the NOS fuel line to (the one that normally goes from the fuel selnoid to the fuel rail)...i can't seem to find a fuel rail...is there some other place where i can tap in???
Thanks for any response
Old Mar 14, 2002 | 09:02 PM
Toronto B6 -OnEighty's Avatar
Default Your doing a NOS install without any help or any guides ?
That's a little scary... NOS is dangerous stuff if improperly used. Either get someone that knows the install to help you or a step-by step guy.
My 2 cents
Old Mar 14, 2002 | 09:08 PM
BoostedA4's Avatar
New Member
your fuel fail is the rail under your engine cover that connects to your fuel injectors.
Old Mar 14, 2002 | 09:18 PM
CharlieGSanD's Avatar
Senior Member
Default here ya go :)
<center><img src="http://pictureposter.audiworld.com/8383/Valvetrain.jpg"></center><p>
the fuel rail is the metal bar you see going across in the very top of the pic.
you will need to remove your plastic engine cover to see it...
just FYI, nitrous on a turbocharged motor can be very tricky & if you dont know what you are doing you "could" cause severe engine damage......
give "Adrenalin motorsports" a call, im shure they will be very helpful..... (you can find thier info in the "links" section)
Old Mar 15, 2002 | 06:37 AM
ND4SPEED's Avatar
New Member
Default I don't think going through the fuel rail is the best way !
Check around. There are special nozzels that adapt to the front of the throttle body, to mix the nitrous with the incoming air. Check out Nitrous Express for more details.<ul><li><a href="http://www.nitrousexpress.com">Nitrous Express</a></li></ul>
iestatic
S4 (B8 Platform) Discussion
Nov 14, 2015 07:23 PM
OrMar
Inline-5 Discussion
Aug 20, 2009 01:38 AM
jimzigg2
13
Mar 11, 2008 05:13 AM
Carl C. Granato
12
Oct 3, 2005 02:28 PM
crazydrvr20
Performance and Tuning
Mar 19, 2002 08:35 AM
