What does the chip do, mechanically?
Old Jan 18, 2002 | 09:16 AM
Vicarious's Avatar
Junior Member
Default What does the chip do, mechanically?
Does it just make the turbo suck in harder? (ahahah)? Or is it something else?
-Confused physics guy
Old Jan 18, 2002 | 09:19 AM
Sourdough Josh's Avatar
Default Re: What does the chip do, mechanically?
It changes the boost pressure of the turbo, yes. At the midrange, it pushes much harder, and at the low and high end, it backs off a little to prevent damage.
On DBW cars (not sure on others), it also matches the increased turbo input with increased fuel.
Old Jan 18, 2002 | 09:26 AM
zain's Avatar
Junior Member
Default What it does is...
Change the amount the bypass bleeds off the turbo before the intake. Boost pressure is regulated by managing this valve. It also modifies the injector pulse width to get the fuel mixture right, due to the air increase.
More air, more fuel. More boom when the spark fires.
- Z
Old Jan 18, 2002 | 09:28 AM
Hokie_Audi's Avatar
Default I think he's looking for how it alters the boost characteristics...
The answer lies in the electronically controlled wastegate. The wastegate opens to relieve excess pressure and the threshold is controlled electronically, buy the ECU. The "Chipped" ECU holds the wastegate closed longer, allowing more boost to build. The chip also remaps the fuel/air mixture tables to take advantage of the extra intake charge pressure.
Old Jan 18, 2002 | 09:34 AM
newaudidude's Avatar
New Member
Is there anything to worry about in terms of more ware and tare on the engine? Will it cause parts to fail early? What to get a chip but worry about my engine
Old Jan 18, 2002 | 09:45 AM
The BPV is completely mechanical. You are thinking of the wastegate, I think.
Old Jan 18, 2002 | 09:51 AM
Default Well
Anyone who says it has no effect is trying to sell you a chip
Yes, it will put more stress on your engine, and will likely decrease the turbo and engine life. The question is, how much, and is it worth the extra boost?
I think it is worth every lost day of car time.
As for wear and tear, our 1.8's are designed specifically for turbo charging, and will likely not suffer noticiably from the increased boost. I get the impression that boosted turbos do burn out faster, though the change in time does not seem to be a significant difference (i.e., I haven't seen differences of 50% or anything like that).
On a final note, if you don't drive the chipped car hard, it will make no difference. If anything, it might actually be easier on your car. So you can get the chip and then not push it, and you'll have absolutely no problem
- J
Old Jan 18, 2002 | 09:59 AM
New Member
Default Re: Well
sounds good. thanks
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 18, 2002 | 10:13 AM
zain's Avatar
Junior Member
Right. Stupid brain fart typing too fast at work. Sorry
Old Jan 18, 2002 | 03:02 PM
EdP's Avatar
EdP
AudiWorld Uber User
Default wrong too.... in a way....
the boost is managed thru the opening and closing of the wastegate in the exhaust side of the compressor. Essentially a dump valve to let exhaust gasses bypass the turbine wheel and not spin it. The wastegate is controlled by the actuator arm and vacuum chamber, which is in turn controlled by the frequency valve. The freq valve is an electrically operated valve that portions off the vacuum to the actuator. this freq valve is driven by signals from the ecu.
So... the ECU as it's programmed, controls when the wastegate starts to open and divert the gasses that are causing the turbo to spin and build intake pressure. The ECU also controls spark and fuel dilivery via the injectors which are also electrically driven. The amount to time spent open and releasing fuel is the duty cycle. Thats a small portion of how the 18't works. Tuners modify the parameters which govern the manner the above mentioned components operate, as defined on two and three dimensional maps and matrices.
cparke
Nov 28, 2008 02:03 PM
Jonny K
Audi Original "S" Cars
Mar 16, 2007 09:40 AM
aviattor.3
Aug 25, 2006 08:16 AM
Audi baby yea!
Oct 6, 2003 07:57 PM
JikJak
Apr 6, 2001 03:45 PM
