What the hell is with the K04!
People are having problems with STOCK ecu's, the chipped cars are running SMOOTHER with either chips I mentioned.
APR found the bug while programming for the '01 STAGE 3. The bug problem in the '01 code is exacerbated with larger turbos. that is WHY you have YET to see a '01 K04 GIAC chip. When it comes out THEN we can talk. The '00 K04 has been in development since JULY 2000 - still not bug free, but promised in a week or two.
Here's the excerpt from Vortex, posted by the owner of the test vehicle.
<b>But I have been workign with AWE/GIAC on the KO4 kit since july of 2K. It will hopefuly be completed next week as they will have my car again for a full week for testing. IT has not been released becaue the bugs have not been worked out....
chris
chris86vw@aol</b>
In reality, we have not done much tweaking to create an 01 K04 kit yet. The main reason being: there is very little demand for one right now. We are prioritizing our current projects, and do hope to wrap the code up on that kit ASAP.
As far as the 00 K04: it is and has been finished for months now. Jenner's TT is an isolated example, and since we did not do the install, I cannot speak on why his car is having issues, or even what the latest status is.
There dozens of other DBW AWE or PES K04 kits with GIAC software in successful use right now, on TTs, A4s, and New Beetles.
Please stop saying that GIAC has not been able to successfully produce a DBW K04 kit for the A4s. This is *not* true.
Your quote is from our Golf/Jetta K04 tester, not from an A4 owner.
Perhaps, but the request to "stop" mis-information should flow both ways, shouldn't it?
My initial post was to correct Mike. For every post you deem as false, I can find 10 false posts concerning APR's products.
For those that WANT a Ko4, I have on and OFF the forum directed them to your company Todd as the source for a quality kit. <B>I</b> can be objective in this.
Lets leave it at that.
One reason I say if you are going with a K04 go to AWE, is they stay in the designed envelope of the K04, namely 235 hp. Those that claim more are pushing the turbo. I'd prefer larger injectors, but a 5 bar FPR will do. Remember, the TT 225 uses a K04. 235 is not that much more aggressive to cause you concern. I'd also consider a FMIC in the future, as reducing the intake temps help reduce detonation. The more you push to the outer edge of that rated envelope, the greater the intake temps are due to turbo inefficiencies outside of its sweetspot.
Lastly, go with a company that will BE there in an unlikely event you need support. This is where bricks and mortar win out.
Disagreements with Todd aside, I'd recommend AWE, who has a great reputation for customer service.
The BIG thing is the internal vaning. All FMIC's I've seen for sale are simply a core and an endtank; the air shoots in, then exits. That means the outer edges of the IC is less efficient, as less/no air charge is being pushed thru it. The internal vaning distributes the air evenly across the entire core body. SInce it's more efficient, the IC can be smaller than one that doesn't have vaning. It's one sweet FMIC. Less pressure drop than stock.
No idea on the release date, but if you're waitng a year, then it'll be out by then, and you'll get t see pics from others that have it installed.
