What is wrong here?
Old Feb 8, 2008 | 05:11 PM
Joey T
Guest
Posts: n/a
Default What is wrong here?
Hint: Number one piston was at TDC.
<img src="http://www.showyourmedia.com/files/1202522837.JPG">
<img src="http://www.showyourmedia.com/files/1202523079.JPG">
Old Feb 8, 2008 | 05:13 PM
bassed-ndzmorezone5's Avatar
3 off? Rut row.
Old Feb 8, 2008 | 05:18 PM
Audiboy's Avatar
pull cam belt sprocket, align cam, tighten cam sprocket bolt.
Old Feb 8, 2008 | 05:23 PM
I fink Joey has it covered by now
Old Feb 8, 2008 | 05:32 PM
Joey T
Guest
Posts: n/a
Default Sorry, 1.8T engine. Cam spocket is keyed.
I had the hardest time working out in my head how the 2.8 deal worked.
Old Feb 8, 2008 | 05:37 PM
Audiboy's Avatar
you got me there. Let's see a pic of the whole cam, or is it half a cam
Old Feb 8, 2008 | 05:38 PM
Audiboy's Avatar
oops, reply was for below
Old Feb 8, 2008 | 05:50 PM
Joey T
Guest
Posts: n/a
Default I have you overthinking.
Sorry, I guess you were looking for more of a challenge than I can offer
MonkeyLover had a slight, err, offroad excursion with his car. Had it towed back onto the road, during his trip to work the next day it started making noise and set a CEL. Noise was bad enough he declined to drive it, had it towed to my shop.
I started the car the next day, no noise. Drove it into the bay, no noise.
Hooked up my VAG-COM.... cam chain tensioner makes loud noise.
Shut the car off, pulled codes...
Cam/crank correlation errors. Rut Roh....
Pull upper timing cover.. that is what I found. Crank at TDC, cam off by what, four teeth.
Tensioner intact, roller intact, belt tight, water pump intact, all teeth on belt intact.
I pulled the valve cover because sometimes the cam will sieze when the engine sludges and the pulley keeps going with the front half of the cam, but his engine looks clean.
Did the timing belt, drove the car, runs great, no noises no codes.
So somehow it skipped four teeth.. and kept running.
Monkey made out pretty well, I did three timing belts today, his was the last one, so I only charged him the labor I needed to hit my goal today
 Pouria Savadkouei
 Michael S. Palmer
AR15Texan
Apr 22, 2010 07:23 AM
VOoDOoGTX
Aug 17, 2007 03:50 AM
AEBlessed (1.8G)
Jul 26, 2007 03:53 PM
quattro s d
Aug 3, 2005 03:40 PM
C5867
Aug 12, 2004 06:25 PM
