wierd boost problems..help!
Old Jan 25, 2003 | 09:39 PM
blk18tq's Avatar
Default wierd boost problems..help!
On full throttle in only fifth gear as the boost startes to taper down on my boost gauge, if it drops below 0.5psi from 1.0psi it goes into limp mode and there is no check engine like, usally after 110mph...but other than that the car runs great in all gears....anyone have any suggestions?
if i restart the car it goes back to normal, until I do it again....;(
my fifth gear holds boost for most of the rpm's but after 5000 it tapers
mods: forge dv: giac chip: itg intake: exhaust:fmic:5bar fpr:
Old Jan 26, 2003 | 07:38 AM
Audi2ptzero's Avatar
Elder Member
Default It is caused by the FMIC. I had that problem all the time when we were testing a EVO fmic on my
2000 since I was the R&D car. The car is going into a soft limp mode and resets when you start the car again. If you check your DTC's you will find a "neg deviation" code.
Old Jan 26, 2003 | 09:50 AM
dleone1.8t's Avatar
New Member
Default I seem to recall you posting those issues, didn't it happen
in more gears tho?
Old Jan 26, 2003 | 11:17 AM
Elder Member
Default It did it in 3rd-5th gear over 5400 rpms.
But most of the time it was in 5th gear on the fwy since that is a straight pull thru 1 gear and the turbo takes longer to spool up. At the drags the turbo is spooled up thru 1st-2nd so is spinning at a higher speed by the top of 3rd gear. But the issue was fixed with the last chips I had for my K03, which ran 20-24psi on the street and the Drag chip which ran 14.2 on 104 octane. I am pretty sure most of the GIAC K03 chips now will get rid of that problem with a FMIC, but still run normal boost levels. I think the main issue was that the boost sensor was seeing the drop in pressure so there was not enough booost at the higher levels, I think the fix was to program the boost levels higher in the upper rpms.
canyoncarver2
Jan 5, 2008 07:55 AM
thewatcher101
Feb 12, 2007 04:06 PM
Stroker//S4
Audi Original "S" Cars
Jan 22, 2005 07:44 PM
Distinct
14
Oct 1, 2004 11:43 AM
ArlingtonS4
10
Jul 18, 2001 03:56 AM
