X Chip issues!
Old Aug 7, 2002 | 04:19 PM
cbagz's Avatar
Default X Chip issues!
I have one issue about the X chip. My cruise control doesn't work! Jeez... Anyone with x chip, does your cruise work? LMK
Old Aug 7, 2002 | 04:22 PM
VicG's Avatar
Default Did you change ECU's to get this x-chip?
Its normally just a bit change on one of the ECU codes...
Old Aug 7, 2002 | 04:27 PM
idge_ca's Avatar
No problem here
cbagz's Avatar
Default It's a spare ECU (M box) w/GIAC X installed.
Could I do this with a VAG tool? or just send it back to AWE?
2001 1.8TQMS
GIAC X
TT 225 BV
Old Aug 7, 2002 | 04:29 PM
TimB's Avatar
New Member
Default Hmmmmmm
You know, I just put my newly chipped ECU back in last night and I haven't tried cuise control yet. I'll try it on the way home tonight and dig up this post tomorrow to let you know...
VicG's Avatar
Default Yes you can... I found this link, it needs a "G" mode added
It's sorta the same for the A4, I'll keep looking.<ul><li><a href="http://mach.mach-nine.com/gti/vwtechcontent/vwpdf/v000010.pdf">Tech Bulletin PDF</a></li></ul>
Old Aug 7, 2002 | 04:30 PM
Greyhound Guy's Avatar
You can use a VAG-Tool
Old Aug 7, 2002 | 04:44 PM
VicG's Avatar
Default With VAG-COM do this:
Select -&gt; 01-Engine -&gt; Login -&gt; 11463 -&gt; Do It!
Afterwards, the "Component" field on the Open Controller / Select
Function screen should have a "G" somewhere in the middle of it. "G" stands for Geschwindikeitsregelung (Speed Regulation).
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 7, 2002 | 04:51 PM
cbagz's Avatar
Default Re: I would if I had a VAG.. Thanks for the HELP VicG!
oh man I need to go buy a VAG tool now.. I don't feel like sending it back, I just got it and loving it. Blows APR out of the water.
Old Aug 7, 2002 | 05:05 PM
Sourdough Josh's Avatar
how you liking it so far? What were you running b4?
