Xpost: Need help with CEL codes
Old Dec 30, 2004 | 09:59 AM
BLKPERL's Avatar
Default Xpost: Need help with CEL codes
<ul><li><a href="https://forums.audiworld.com/vag/msgs/6010.phtml">Error Codes: 17544 &amp; 18010</a></li></ul>
Old Dec 30, 2004 | 11:07 AM
BigEd's Avatar
Member
Default The lean code is probably due to a vacuum leak. If you have a hard time inspecting the hoses
Then do a pressure test of the intake system. You will need to either build a kit or take the car to the shop. The kit is easy to build but you might have hard time limiting air pressure to 7 psi, - will need a special adapter and the inexpensive ones I've seen lack precision.
The second code is probably due to low battery voltage. Take the battery to a shop for testing. For example, in my neck of the woods BatteriesPlus tests them for free.
Let us know what you find out.
mking54
A4 (B8 Platform) Discussion
Mar 5, 2018 05:41 PM
adrian.denizs4
16
Dec 30, 2009 01:17 PM
fhpski
VAG-COM Discussion
Aug 18, 2008 02:34 PM
BLKPERL
Dec 30, 2004 09:55 AM
