110K update....
Old Feb 11, 2007 | 08:52 AM
IOKEPA's Avatar
Senior Member
Default 110K update....
car still running strong. had a few minor problems fixed yesterday.
1 - A/C: i had recharged the cooling system a few months ago and now the AC wasn't cooling again, WTF? turns out my cooling systems had been leaking so i had the valves replaced and added new freon. AC working back to normal again, nice and cold.
2 - CEL: DTC said my car was running lean. this was to be expected because the hose going to my boost gauge came off. besides the old hose was kinked so bad it needed replacement. new rubber hose installed and now my boost gauge works again. also i regained more power/boost and car drives even faster. very noticeable different in acceleration, almost like going from chipped to big injector file.
<i>Thanks to Jose @ <a href="https://forums.audiworld.com/socal/msgs/8316.phtml" target="_blank">Euro-Tech (Culver City, CA)</a> for taking care of the 2 things above, and especially for squeezing me in even with all the other cars he had yesterday. It was almost like a mini-GTG, running into a few familiar faces (MSAR, Sterni, etc)</i>
3 - driver rear power window regulator: this one i did myself. I figure if that NOOB PuRe can do then i could easily do this . I picked up the window regulator from E&amp;C VW Auto in Reseda for a $106. install wasn't too bad, it did take about an hour. if you should try to attempt this, do yourself a favor and buy one of them torx bit sets (T-15 to T-45) prior because the door disassembly used about 4 different sizes throughout. could have been a quicker job had i figured out how to remove the door insulation all around the window sooner. rear power window is now working again.
Other issues I still need to address but didn't have time or the part yet -- ABS control module replacement, aligning my exhaust tips and possible exhaust leak, and getting rid of this rattling sound from the rear (probably loose bolt on my rear sway bar).
Old Feb 11, 2007 | 09:25 AM
needforsleep's Avatar
Default good to hear the car is running well....
the rattling on your exhaust could be your piping hitting the drive shaft. When my exhaust was mis-aligned it was causing a rattling sound on turns or large bumps. We put it up on a lift and saw the witness marks on the drive shaft of where the exhaust was hitting it.
Good luck with your remaining issue.
Old Feb 11, 2007 | 10:09 AM
IOKEPA's Avatar
Senior Member
actually the rattling was existent before i had my exhaust put on but i'll still look into that
Old Feb 11, 2007 | 04:21 PM
gimik's Avatar
Default did the window regulator job require anything crazy?
i read a couple how-to's that said you need a rivet gun etc..
Old Feb 11, 2007 | 05:05 PM
IOKEPA's Avatar
Senior Member
Default not at all. all you need is a philips screw driver and a torx set, thats it.
no other special tools. theres just a lot of bolts to unscrew but very straight forward.
Old Feb 11, 2007 | 05:19 PM
gimik's Avatar
did you follow any tech articles/guides to do it?
red1bw
S4 (B8 Platform) Discussion
Oct 20, 2015 08:48 AM
lwjenn01
Sep 25, 2015 03:41 PM
mobaar
Nov 16, 2005 07:06 AM
wclepse
Nov 1, 2005 10:15 AM
BSCA4
Feb 24, 2004 06:56 AM
