16804 code
Old Mar 30, 2012 | 09:53 PM
StealthTT's Avatar
Default 16804 code
Hey looking for some help on this error code, came up as catalytic converter below threshold. So from what ive read its either one of the 02 sensors, exhaust leak, maft issues or the cat is damaged. I can do all of the work myself no issues but im wondering how to inspect the 02 sensors to determine if theyre screwed, or inspect the cat or maft to figure out what is causing the issue. Im trying to do this on a budget so instead of replacing everything id like to pinpoint which is causing issues, ive only had the vehicle a week so i dont know the history if anything has been done already, its an 02 a4 1.8l with 151k km on it no real issues so far. If i do need to replace the cat what would you recommend and where are they cheap online?
Thanks in advance for any help
Old Mar 31, 2012 | 04:55 AM
rohit13's Avatar
If you get just the p0420/ po430 then it's probably the cats. If you get codes for the 02 sensor that's bank 2 then it's possible the 02 sensor is bad
Try the cheap 20 dollar trick. Buy spacers and go from there. That doesn't work replace cats
Pchelka01
Audi allroad
May 12, 2012 08:44 AM
rohit13
9
Dec 23, 2011 11:08 AM
bcarter2138
11
Jan 7, 2010 05:46 AM
Forest37
Jul 23, 2008 07:02 AM
escargot
Performance and Tuning
Dec 19, 2003 08:26 AM
