4 Month Long CEL Saga: 16683 - Boost Pressure Regulation: Control Range Not Reached... (help)
16683 - Boost Pressure Regulation: Control Range Not Reached P0299 - 002 - Lower Limit Exceeded
for nearly four annoying months and was wonering if guys/gals can lend a helping hand.
My car is an 04' A4 1.8TQM with the following powerplant mods:
APR Stage II+ (subsituted the exhaust w/the Thermal R&D race) running on software v 2.0.
TT225 Injectors
Forge DVR w/Yellow Spring
NGK BKR7E's.
When the CEL first popped up back in May, I vagged the car and discovered that it was getting the "16683" code. I cleared the code and about a week later, the CEL popped up again.
Afterwards, the following steps were taken to diagnose the problem:
1. called APR: "It's an hardware problem..."
2. took it to the dealer to check for boost leaks and examine the DVR: none
3. took it to the dealer again for the smoke test: negative.
4. took it to the dealer yet again to get the boost actuator replaced.
By this time, I was seeing the "16683" regularly and clearing the code every week or so.
At the same time, I've contacted Andy @ Ross-Tech for suggestions and he furnished me with the usual battery of tests: 1. boost leak 2. dv 3. n75 4. software
Called APR again, "It's an hardware issue..."
Thinking that it might be the Forge DVR spring problem, I've switched the stock spring (green) to the next step up (yellow). This did not resolve the problem either.
So with the VAG, I measured and logged block 115:
<img src="http://www.ncaudi.org/gallery/albums/album258/Requested_vs_Actual_Boost.jpg">
As far as I can tell, the result seemed fine.
Has anyone else had this problem? If so what/how did you remedy it?
I am pretty much at the end of the rope and thinking whether I should get the car reflashed again or tinker with the n75 valve.
APR says their software is perfect, so what can I say?
Thanks in Advance <img src="http://www.audizine.com/forum/images/smilies/race.gif">
SP
I met someone here with their Stage 3 and it as been nothing short of a nighmare for him so far.It as been months after months of wrestling with them to get parts and still the thing doesn't run right.
