aligning ecodes.
Old Mar 3, 2005 | 07:41 PM
Sharm's Avatar
Default aligning ecodes.
Hi, Nothing ever just goes smoothly.
I just replaced my stock halogens with bi xenon ecodes. The lights are great, but the beam from the drivers side light is a lot lower than the passenger side.
I know it's supposed to be a bit lower, with a step but this is a lot. When I adjust using the adjuster, I can only get it to move a little bit before it reaches the end and starts clicking.
Any ideas what might be up? The adjuster is adjusting, just within a narrow range. Anyone had a similar problem?
Cheers
Old Mar 3, 2005 | 07:51 PM
akula-ssh's Avatar
Default Have you tried adjusting the other ****?
As I said before, the two controls are not exactly independent of each other, so if the "horizontal" adjustment is way off, the "vertical" one is also compromised.
Old Mar 3, 2005 | 07:59 PM
Sharm's Avatar
Default Re: Have you tried adjusting the other ****?
Yes tried both - the one under the hole I made moves up and down a bit - the other one doesn't seem to do anything much at all, but I assumed it was because you need some distance between the car and the wall to see it.
Old Mar 3, 2005 | 08:05 PM
akula-ssh's Avatar
Default What if you left the "horizontal" one essentially halfway?
Does the give you a bit more vertical adjustments?
Old Mar 3, 2005 | 08:08 PM
Sharm's Avatar
I'll play around with it again. Make sure I'm not completely insane.
Old Mar 3, 2005 | 08:24 PM
akula-ssh's Avatar
Default If it still doesn't work...
I guess you'll just have to pull it out, open it up (like you're replacing a bulb), and find out first if anything's broken, and (hopefully) if nothing's broken, how the auto-levelling motor moves the headlights, and try to adjust it up a bit that way.
Old Mar 4, 2005 | 05:08 AM
Hakon's Avatar
same with halogen ecodes- driver side beam is considerably lower
Old Mar 4, 2005 | 06:04 AM
CO AVANT's Avatar
Default I had this problem w/ my passenger side...had to send it back cause there was a piece broken........
internally(little white mounting tab for lenses)...this caused the light to point down...too far for correction.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 4, 2005 | 07:08 AM
akula-ssh's Avatar
I fixed that problem with a little zip tie; works like a charm
Old Mar 4, 2005 | 09:19 AM
CO AVANT's Avatar
I said F- - - it and sent it back for a new one...$500 for a broken light? I don't think so.
