ARGH!!!!
Old Dec 4, 2009 | 01:42 PM
crstna09's Avatar
Default ARGH!!!!
So, I'm begging to think my A4 is the biggest hunk of junk on the planet. It's been nothing but problems since I bought it. The most recent, it completely cut out one day while driving home from work. Every light on the dash was on and it would not restart. I finally got it back across the street to the shop, and the mechanic said the ABS module was bad and causing miscommunications for pulling codes.
So . . . now I have a new ABS module in, but the car still will not start and all the lights are still on (ESP, ABS, Check Engine). The battery was unhooked for half an hour, so the computer should of cleared right? I haven't pulled codes yet, still waiting for the cable to arrive to do so with VAG-COM.
The start to the whole thing was what I assumed was watered down gas, the car started to sputter under acceleration shortly after filling up from one particular gas station. But it seemed it had gotten better, even stop sputtering the day before it completely died.
Anyone have any ideas?
Old Dec 4, 2009 | 05:28 PM
audi_buff's Avatar
You say it will not start, but does it crank? Does the starter do its job?
You obviously have power since all of the lights are on.
If it cranks but doesn't start I'd say fuel pump.
Did it run rough at all before or just suddenly die?
Old Dec 7, 2009 | 06:45 AM
crstna09's Avatar
Yes, it has power and the starter does turn over and make an attempt. It did sputter under acceleration before it just completely died, but it had stopped doing that the day before it died.
Old Dec 7, 2009 | 08:44 AM
mayhem100's Avatar
Maybe multiple bad coilpacks?
Call me paranoid, but I don't trust mechanics on my wife's Audi anymore, even the dealer incorrectly identifies problems most of the time.
Totally differnet animal of course, but my 2002 Nissan Altima died on the road shortly after I bought it...like I was cruising along at 40mph and the motor just cut out on me. Bad camshaft position sensor in that case. NNa later issued a recall.
Old Dec 7, 2009 | 11:30 AM
audi_buff's Avatar
40mph and it cuts out? That's gotta be nerve-racking...
For the sputtering issue I'd say coil packs or fuel pump. If it's not getting any fuel and is just burning residual in the line then that would cause sputtering.
I may be on track to replace my coil packs (one or all) after it started shuddering and flashing the CEL at me last night. At least I was going slow and near a parking lot.
At least coil packs are only $150 for 4, which is pretty cheap vs a fuel pump or even a tow. (My tow cost me $128...)
Good luck and let us know if you find anything else. Do you have a Vag-Com? Oh, and is the CEL flashing or does the car say everything is well?
Old Dec 7, 2009 | 02:18 PM
Lyman_T's Avatar
Immobilizer?
paul_858
Sep 6, 2001 08:28 AM
Mikey L
Jul 27, 2001 06:00 PM
fdxboy
Jun 16, 2001 12:56 PM
elton
Jun 29, 2000 04:13 AM
SK
Sep 21, 1999 08:43 AM
