COOLANT ?
One other note. I have never had a problem bleeding the system, but other have. I have just filled the reservoir to the max level, started the car, turned the heater on, and keep filling until the coolant stays at max. That has been enough in my experience to bleed it properly. As always, watch you coolant temp closely for a while after you do the work.
I'm concerned about that "cracked head gasket" comment. Those don't normally, if ever, "crack". An engine that has lost coolant for any number of reasons, and then over-heated will often cause cracks in the Aluminum cylinder head, or distort enough for the head gasket to fail.
Regarding filling the system, having the heater "ON" has no effect either way (there's no heater coolant valve) but running the engine during filling will usually lead to air trapped in the heater pipes. The pump has to be stopped for the coolant to rise and force air from the bleeder hole in the heater discharge hose.
re: head gasket:
If so maybe I just have to replace the head gasket? how much will it cost to replace the head gasket, including the labor and stuff?
I also drove a Merkur (2.3 Ford turbo) that only lasted about 1000 miles when I started to think the head was leaking. Turbos are usually much harder on heads that normally aspirated. Only way to know is to fill it and watch the coolant level. Cost to replace? $1500 to $2000.
