Driver's information panel problems
Old Oct 20, 2004 | 12:03 PM
nikitos1979's Avatar
New Member
Default Driver's information panel problems
Hi, ever since I got the a4 1.8t about a year ago, the information panel (one that lists radio station, open doors, etc) has been getting static lines through it more and more, and now when I'm driving its completely black. If I hit low fuel level or open a door, it lights up again, but I dont ever see radio/cd/temp information any more. Is there a way to fix this (reset battery or something) or do I have to get a whole new panel?
Old Oct 20, 2004 | 12:13 PM
Turbosport's Avatar
AudiWorld Expert
Default whole new guage cluster if i'm not mistaken
should be warrenty though, so it shouldn't be a big deal
Old Oct 20, 2004 | 12:14 PM
Boston Driver's Avatar
AudiWorld Expert
Default Dying display...will need to replace the whole dash panel...
same issue with some on the A6 forum. The center display is not available as a seperate part. You will need to have a dealer install, and set the new dash panel with correct mileage.
Some notice that on warm days, it gets worse. Hopefully, you are covered under warranty. No factory recall on these, but a known problem.
Good luck!
Old Oct 20, 2004 | 12:27 PM
Ultrasport-Sal's Avatar
Junior Member
If the whole display is blank, did you by chance turn it off? Hit reset on bottom of wiper switch.
Old Oct 20, 2004 | 01:00 PM
uktena's Avatar
Junior Member
Default That is correct....
I found this when I wanted to change mine to the color display from the S4.
Old Oct 21, 2004 | 04:37 AM
AudiWorld Expert
Hey, I did not know that there was an off switch! Cool!
raiderrider
12
Sep 8, 2015 05:46 AM
fkaufman
A7
Sep 7, 2015 07:59 PM
zjw8407
Sep 2, 2015 05:20 PM
stormchaser1967
Sep 2, 2015 09:26 AM
