Ecode help
Old Mar 11, 2004 | 07:47 AM
BoostedA4tQ's Avatar
Default Ecode help
Please let me know how to install the ecodes is the wiring all the same...and what size bulbs are for the corners..will everything work properly...and the city light do i need to do any wiring or can i plug and play...
Old Mar 11, 2004 | 07:50 AM
HighPSI's Avatar
Default It's all just plug and play, the wiring harness you have fits right in and the parking light postion
of your light switch now turns on your city lights, cant remember what size bulbs though..also this is for halogens...not sure if xenons are same
Old Mar 11, 2004 | 07:54 AM
Jazzm@n's Avatar
Blinkers are 3457
Old Mar 11, 2004 | 07:55 AM
Hakon's Avatar
Default halogen?
it "plug & play", assuming you can unplug OEM headlights. i broke stubborn left plug. city light is already pre-wired so you have nothing to worry about.
make sure you have all bulbs at hand. i have stealth bulbs as indicators (tried phillips & diadems, but stealth looks best). for city lights
i use PIAA, since OEM 5W is too yellow.
Old Mar 11, 2004 | 07:59 AM
On the ecodes its not 3457 its like py21w....am i correct...
Old Mar 11, 2004 | 08:34 AM
nexlvl, Dean@Evil U.'s Avatar
Junior Member
Default How long have you had the Stealths in?
I just bought a pair and someone told me that the silver (on the outside) wears off easily. You noticed this?
Old Mar 11, 2004 | 08:50 AM
Eddie Man's Avatar
Yes, or #1156 for Stealths.
Old Mar 11, 2004 | 08:57 AM
Eddie Man's Avatar
Default I've had mine in for since Nov. and there has been an ever...
so-slight degradation of the silver on the sides. Didn't really notice it though.
My inclination is that if you use the Stealths on eCodes, the corner turns will be on a fraction of the non-eCodes. They only flash when called upon as opposed to always on when called on for the non-ecodes (on & flash). Hence longer life and longer silver life.
 Michael S. Palmer
Old Mar 11, 2004 | 09:01 AM
Junior Member
Default Well, that's the thing...
I bought them for my CC mod. So I'll be using them all of the time in NA spec light housings. Oh well, they really weren't expensive.
Old Mar 11, 2004 | 09:07 AM
Eddie Man's Avatar
Default My take is run'em till they die or become unsatifactory. They will replace them under...
there "lifetime" warranty...I've already had to call them out on this and it was NBD. Their service is awesome. For that warranty issue, they also threw in their Stealth side-marker bulbs for my troubles !!!
