Electrical ISsues
Now I have several anomalies occurring at the same time. The headlights will not turn off, the 4-way flashers go on whenever they want and may or may not turn off. The wiper run on their own for a few minutes then stop.
At one point the windows would not roll down. All of these problems seem to come and go without any direct correlation.
I pulled the dash apart and could not find any water inside at all. Also pulled the computer module out and no water or moisture there of any kind either.
I know I will have to go to the stealership eventually, but if anyone could give me their thoughts I would appreciate it.
It is also possible that lightning caused these issues and the water is just coincidental.
Thanks for your help!
http://www.youtube.com/watch?v=ve6XGKZxYxA
As s4master says, wet electronics. But you also need to fix the cause which is likely clogged drains. Do a search for drains and you should find lots of info. Been covered here several times.
They also tell me this needs to be programmed. Is this something I can do with the Ross Diag software and an interface? The dealer says it will run anywhere from $1000 to $2500 to repair this issue.
wondering if I can do this myself.
