Electrical problems
So I begin the right front fog lamp does not come on shows up as a bad bulb on the dash indicator but the bulb is good as I swapped it with the left side and it worked, and two the open door indicator on the dash when I open the driver's door it shows up as the passenger door is open and when I open the driver's door it shows up as the passenger door all the other indicators work trunk hood left & right rear doors, also when I check the doors with vcds lite it shows the correct door when I open it driver or passenger oh other than the bad bulb indicator no errors with vcds.
Thanks in advance for your help.
