engine check light
Old Sep 23, 2012 | 09:24 PM
gradie's Avatar
Default engine check light
Hi guys I'm a new newbie here, I bought a 2002 A4 1.8t 4 door, 5 speed, with 113000 k's I washed the engine compartment and the engine check light came on, I'm not sure on how to get a code. Or can you re-set it?? It's dry, I took her for a little cruise well into the excessive range just to make sure she was dry! I think handles pretty good, I've had a couple of bemmer's over the years. 320i and 2002ti. I could use some of your expertesece.
Old Sep 24, 2012 | 02:21 AM
lyleswk's Avatar
No telling. I would drive it for a couple of days and see if it goes off by itself. Otherwise, you will have to get codes downloaded. I would highly recommend you get your own VAGCOM reader or locate a friend with one.
Old Sep 24, 2012 | 05:42 AM
gradie's Avatar
Thank You I'll google VAGCOM reader.
Old Sep 25, 2012 | 06:50 PM
gradie's Avatar
So I borrowed a scanner and got the code P1296 which is a cooling system malfunction. So do you need to rip out all the cooling systems sensers????
Old Sep 26, 2012 | 04:41 AM
srlbotanical's Avatar
Originally Posted by gradie
So I borrowed a scanner and got the code P1296 which is a cooling system malfunction. So do you need to rip out all the cooling systems sensors????
Does the scanner you borrowed clear codes?
I bet you got a little water in one of the connectors and that threw the code. hopefully the engine heat has dried everything out and once you clear the code it wont show up again...
Fingers crossed for you!
Steve
Old Sep 26, 2012 | 05:49 AM
gradie's Avatar
yes it did have a button to clear so I cleared it.... but I still have a temp. gauge thats fluctuates.. it comes to temp then drops back down to a quarter on the gauge..then repeats everytime I shut down and restart... well most of the time.. any ideas???
Old Sep 27, 2012 | 02:43 AM
lyleswk's Avatar
So if I understand, you no longer have the CEL? And you did clear the code? If so, I would give it a little more time. If it continues to happen, it is probably the "green" temp sensor at the back of the engine. Easy swap and inexpensive.
Old Sep 27, 2012 | 07:13 PM
gradie's Avatar
thank you!!! I'll look for one it's probably best to buy OEM?? right.. is there some place on the net that has diagram of the cooling system?
 Michael S. Palmer
Old Sep 28, 2012 | 11:37 AM
Prospeeder's Avatar
It could be that you cooled a part of the cooling system down abnormally with the water and the temp sensor saw it like a stuck open thermostat and set the code.
Old Sep 28, 2012 | 08:51 PM
gradie's Avatar
She was cold as ice... I'm not one for cooling down the engne by throwing cold water at it... I'll start with the back (green) senser first....
