Everything was going so well and now this...
Awe-Tuning FMIC
APR TIP (I doubt it's collapsing but I did bang the N75 around quite a bit installing it, maybe it just gave up and died)
TT HFC
Awe-Tuning Cat-Back exhaust
EVOMS intake
Stratmosphere HXc DV
That's about it.
Maybe I'll do a boost leak test tomorrow. Last time I had a boost leak though, I couldn't boost more than 10 psi.
Try logging other mb values concurrently with mb 115, like O2 sensors, lambda, ign timing knock control retard, IAT, etc, to see if there is some other parameter that is deviating from normal along with the reduction in actual boost pressure. The ECU response could either be based on accurate sensor data or faulty sensor data. Or, it could be an ECU adaptation defect involving the ECU tuning re mappings.
BTW, if the N75 was defective, (opening early or stuck partially open,) then it is likely the achieved boost would not reach the specified values at any point. From the graph, I believe the boost control system (N75 and wastegate/actuator mechanism,) is OK, and is responding to the ECU accordingly.
<img src="http://i132.photobucket.com/albums/q33/x1rider/lambdagraph.jpg">
I looks like the curves are very similar except for a few deviation spikes (maybe when I was shifting). If you need the actual values of the logs, I can email them to you.
CF (cyl1 to cyl4).
<img src="http://i132.photobucket.com/albums/q33/x1rider/CFgraph.jpg">
The maximum CF is 6 (which I regularly get). I have heard rumors that the 91 gas here is not really 91, we are getting screwed on that. One of my friends has a Harley that kept on pinging when riding in town and as soon as he went down south and filled up there, the pinging magically stopped.
I'm looking to get some xylene at the local paint store and I'll try raising the octane level or our "91" and see what it does.
Do you think it's worth it to order a N75 and give it a shot anyway? My car has 100k miles, it wouldn't exactly be a luxury!!!
I'll do a boost leak test this afternoon and see what I come up with. Also I'll look through the logs and see if the boost drop corresponds with the higher CF's.
Thanks Diagnosticator1!
It won't hurt to replace the N75, other than the cost of a replacement.
Also, interpreting the data would be easier if you use a graphing app with finer resolution.
The graphed spikes/points for the lambda, known as "data outliers", are common, and not usually significant in relation to the data "on curve", and based on the context of the data collected, is often omitted from the graph.
As you can see, the CF's and boost rise/fall at the same time, other than that it doesn't say much. The O2 sensor looks like it's OK because the lambda specified/actual are fairly close right?
I remember a few weeks ago, I did a few runs and was peaking at 19-20 psi and holding a solid 17-18 psi after the peak.
Right now I'm thinking either boost leak that seals ok until 18-19psi and then starts letting air out or a defective N75 dumping boost too soon. Do you think I'm on the right track?
Maybe I should log wastegate duty cycle?
Thanks.
The coincident variation of CF and the
boost achieved, is an important clue to the situation occuring. The fact that the boost achieved, is being lowered, and not the specified boost, suggests that the variable factor involved, is not a standard value used in the torque demand calcs, but is instead, a result of a protective action by the ECU, or possibly caused by variation of a boost relevant parameter not directly monitored or controlled by the ECU.
Logging the N75 duty cycle along with mb 115, would be very useful, to determine what may be effecting the boost levels observed.
Data collected while logging concurrently two measuring blocks, will have the required time stamp coordination for real time comparisons.
