Few Problems
Old Mar 16, 2005 | 09:27 AM
aca's Avatar
aca
New Member
Default Few Problems
I have several small issues with my '02 1.8T and was wondering of some other experiences with similar problems.
1. Left front speaker cuts in and out
occasionaly. It has not done it in a while.
I searched the forum, but could not get a
conclusive answer as to what has been a solution
for most.
2. Driver's window switch paint is peeling off. I
am not sure if it is worth having these guys
take the panel down for that. As bad as they
are in Kansas City,I am not sure if they can
put it back together without damaging something
It is the only Audi dealer in town.
3. Cold start produces a little rattle sound at
idle, coming from under the valve cover. I am
suspecting valve lifter noise. From day one she
was getting oil changes every 5000mi, with oil
in accordance with the TSB. I am using Mobil 1
0W-40.
So, just wondering if anybody else had similar symptoms and what the solutions were.
Thanks
Old Mar 16, 2005 | 09:29 AM
Bob Loblaw's Avatar
Senior Member
Default solution for #1
there was a service bulletin issued to Audi a while back re: bad speaker wiring (harnesses, I believe). Mine did the same thing as you described and they replaced all the harnesses under warranty.
Old Mar 16, 2005 | 09:45 AM
bhvrdr's Avatar
Default #3 sound like the cam tensioner. I used a bit of M1 15w-50 to quite it down...
You can alway mix in a quart or two of it at your next change. If it gets worse, it may need replacing. cheers! Mike
Old Mar 16, 2005 | 09:48 AM
aca's Avatar
aca
New Member
Thanks to both of you
Old Mar 16, 2005 | 09:56 AM
aca's Avatar
aca
New Member
Default I will look
that TSB up and take it to Audi shop and have them change the window switch at the same time.
Thanks for info.
Old Mar 16, 2005 | 10:05 AM
heateris's Avatar
i took my car back 3 times for the door speaker. last time they replaced the clips. no probs since
Old Mar 16, 2005 | 10:40 AM
CBerten's Avatar
Junior Member
Default easy solution to #1
My speaker did the exact same thing. I got so annoyed at it that I punched it really hard a few times and it has worked fine ever since. It's a well known problem though and this is obviously not the most professional solution, but it works
Old Mar 16, 2005 | 10:53 AM
821 dtw (Greg)'s Avatar
Senior Member
lol
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 16, 2005 | 11:05 AM
Bob Loblaw's Avatar
Senior Member
you do TV repairs too?
Old Mar 16, 2005 | 11:28 AM
RareAir's Avatar
Default #2 solution...
Have them fix it. I have had them replace all 4 door window switches. Good as new.
There is a lot of trim where the rubber covering has chipped away. I've never had an issue with them replacing any of it in my car. My replaced items list:
all 4 window switches, ESP Button, passenger side floor vent, center console, CD player, driver seat height adjustment handle.
