Flashing CEL on AMB Engine Code
Old Jan 19, 2008 | 11:15 AM
diehlryan's Avatar
Default Flashing CEL on AMB Engine Code
Coilpacks?
Just had the wifes car towed to my house. I was just going to swap new coils in and see if that solves it.
Anyone with part# for these?
SOmeone mentioned something like a second stage that could be bad too? Whats the deal on that?
Old Jan 19, 2008 | 11:35 AM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Re: ...
...<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/1039200.phtml">https://forums.audiworld.com/a4gen2/msgs/1039200.phtml</a</li></ul>
Old Jan 19, 2008 | 11:38 AM
diehlryan's Avatar
Default Your post is NO help at all. Appreciate it.
Can you answer the 2nd question. What is this second stage thing the other guy mentioned?
Old Jan 19, 2008 | 11:45 AM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Neither is yours...
Flashing CEL needs to have the DTC codes read from it, otherwise you and everyone who replies is guessing at what the trouble is!
You'll wind up changing parts which dont need to be changed, and or spending excess money, trying to put the light out, instead of fixing the actual problem...
My post is a big help, if you actually follow it.
Otherwise your troubleshooting in the blind, and fixing blindly...
Old Jan 19, 2008 | 11:48 AM
quattrothatcould's Avatar
Default If the car was shuddering while driving then it may be a coilpack, but w/o codes you don't know
which cylinder or how many failed. I'm not sure of the part number, but the 'R' revision is the latest. Get 4 (assuming 1.8t) as the other coilpacks (if one actually failed) will most likely follow suit
Old Jan 19, 2008 | 11:59 AM
diehlryan's Avatar
Default You're still not answering my question.
I understand the benefits of Vag.
I also have a TT.. last week my car did the same, flashing CEL and misfires, thats what the A4 is doing.
I'm going to swap the coilpacks.. but what the hell is this other thing I've heard about?
Old Jan 19, 2008 | 12:01 PM
diehlryan's Avatar
Default lets weigh out your solution vs mine...
$400-500 for rosstech and cable then whatever needs fixing..
or
$120 for coils and that may or may not solve problem then add'l if it doesnt.
I just want to know part number and what the other 2nd stage whatever it is is..
I dont mean to be rude but showing me a picture of rosstech doesn't help at all.
Old Jan 19, 2008 | 12:06 PM
AmarilloA4's Avatar
New Member
Default If no VAG -Com available go to Auto Zone and have them pull the
CEL codes. You can then google them to get somewhat of a idea as to the cause.
You REALLY need to offer more info when you post with a problem...
Old Jan 19, 2008 | 12:08 PM
diehlryan's Avatar
Default Funny how when I search flashing CEL every post comes back
w/ coilpacks..
not we need to run codes.
I'll let you guys know when I replace all the coils and the flashing goes away that I fixed the problem.
The only reason you would want to run codes is to see which cylinder is misfiring.. even then its not wise to replace just the faulty coil.
Old Jan 19, 2008 | 12:09 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Mines not a "solution"...
but 1 step in the process, to determine why your car has a flashhing CEL...
Using the "Search Forums" feature, will easily find both answers...<ul><li><a href="http://vag-tool.kicks-***.net/">http://vag-tool.kicks-***.net/</a</li></ul>
