Flywheel timing?
Old Aug 11, 2012 | 08:47 PM
Azzazzyn's Avatar
Default Flywheel timing?
Ok, so I've done a bit of searching and haven't come to a solid conclusion. I have an 03 a4 quattro and I'm in the middle of a clutch/flywheel replacement. We got everything pulled, got the old clutch and flywheel off, put the new ones on and were ready to start putting it all back together when i noticed the flywheel had a timing mark.
This is my first car outside of the nissan world and I've done the clutch on my old 240, so I am just a bit confused by this is all. I've read in a few different posts across the net that if you have your flywheel on, bolts lined up etc, you're good. I just want to be absolutely sure before i put it back together if i have to do anything specific with the flywheel and the timing and where I would be lining it up if so. Thank you for your time.
Old Aug 14, 2012 | 04:43 AM
Flo 1990 90Q 20V's Avatar
Default Flywheel timming
The timing wheel bolt patern is aranged so you can't missalign it.
Old Aug 16, 2012 | 09:58 PM
Azzazzyn's Avatar
thank you. we realized that after I posted this up. The bolt pattern is set up to where it can only go on one way. Again, thank you.
klann187
Oct 15, 2010 08:43 AM
pureroundcircle
Feb 21, 2010 10:46 AM
maaliish
Jul 19, 2006 06:46 AM
rothtimo
Sep 2, 2005 04:24 AM
myfirstimport
Jul 25, 2005 05:03 PM
