front upper control arm replacement
Old Dec 7, 2004 | 06:52 AM
Matt Devo's Avatar
Default front upper control arm replacement
has anyone here had reason to replace their front upper CAs yet? If so, did you just get OEM replacements, or aftermarket (CPP?)? The bushings and ball joints on my CAs are shot (and I'm well out of warranty now), so I'm replacing them with "upgraded" CAs, and I'll replace the tie rod ends at the same time. Total cost for parts (including nuts/bolts etc) from a local shop is ~$550. Any tips for the install are appreciated =)
Old Dec 7, 2004 | 06:57 AM
Jimax's Avatar
Default this is one question you actually may want to post in the B5 forum Matt
they've done a lot more of these than B6ers have.
Old Dec 7, 2004 | 07:00 AM
Matt Devo's Avatar
the parts are the same too, apparently
Old Dec 7, 2004 | 07:05 AM
HighPSI's Avatar
check ecstuning, i believe that have a whole kit
Old Dec 7, 2004 | 07:08 AM
crew219's Avatar
Default "upgraded" or "HD" ones are basically stock. It refers to a change that they made in the bushings (m
in 2001 when they realized that they were crapping out like crazy. Thus you already had the "upgraded versions" from the factory.
I'm not that much of a fan of the CPP kit since the ball joints tend to wear out prematurely. My friend pulled his off at 5k and they were loose as hell. He sent them back to CPP and they said that they were perfectly fine. I dunno . . . . he was getitng a lot of chattering with them over bumps & etc.
Old Dec 7, 2004 | 07:13 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default CPP links probably aren't the best idea for a high mileage street car.
1. Alignments become a chore (and will likely be more expensive once the mechanic learns what a PTIA it is with the adjustable links).
2. Those heim joints are exposed to the elements, which means they are susceptible to more wear and tear than a sealed OEM component. Do you want to yank them out in 20K to have them rebuilt?
Old Dec 7, 2004 | 08:06 AM
JeffPGH's Avatar
Default How many miles on your car?
Just out of curiosity...
Old Dec 7, 2004 | 08:49 AM
Matt Devo's Avatar
just about to hit 60k
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 7, 2004 | 10:16 AM
JeffPGH's Avatar
DAMN! Not looking forward to replacing control arms every 60K miles.
Old Dec 7, 2004 | 10:38 AM
Krendor's Avatar
Default $300 for oem from ecs, did you price stock from dealer??
dang I'm feeling for you as I don't want the same!
are you sticking with you koni coilovers?? do you think played any part in the wear??
