Happy Fun-time upper control arm pinch bolt, yay!
I checked the threads on here quite a bit, especially the one from xtreetoes (https://www.audiworld.com/forums/sho...php?p=18034303). I'd soaked the bolt about two nights before ever touching it knowing that it would be a bear to remove. Today when I tried to remove it, the bolt rotated out about 1cm then started to slowly bind. I sprayed it with more penetrant, waited and came back. It spun a bit more then the bolt head sheared right off, great. So I took the next step and tried to use the threaded end with stacks of washers/nuts to see if I could pull it out from that direction. No go, the threaded end is a bit mangled now as well.
So, I'm left with a mangled up threaded end on my pinch bolt and another end that is sheared flush with the surface (the bolt head end). I tried a bit of pounding with a punch and it doesn't move. At this point it's probably time to get medieval and drill it out.
From what I've read the next best thing to do is get out the drill and sawzall. I'm a bit worried about not drilling straight down the bolt. I suppose since I'm replacing the upper controls arms it shouldn't be too big of a deal. I'm more concerned about drilling out parts of the aluminum mount. I guess it wouldn't matter a whole lot as long as I don't remove to much material. The upper control arms are mainly held by the pinch bolt and the friction between the mount and the control arm ends. If I bore that out a bit will it be bad?
Audi charges 115/hr near me. Weigh it out. If you bring them what you have now it will cost you much more than buying the knuckle. With that new knuckle, it will take you about an hour to put each side back together.
Good luck. This job sucks!
Thanks for the reply, I'm in CT near Hartford and will grab the knuckle if all else fails. If I do get a new knuckle, I'm going to introduce my Sawzall to the existing knuckle and upper control arms with much gratification
I'm going to give it another try tomorrow with a center punch and a bigger hammer. What if I drill out a few cm of the bolt and insert a slightly smaller diameter rod I can hammer on?
As you can tell I'm reluctant to give up but may put myself in a worse situation by not.
I used a center punch and damn near broke my hand. I tried to drill and went off center. I kept the knuckle and control arms to recycle as scrap. The only bright side is that aluminum is getting over a dollar a pound now.
Good luck to you and great to see someone else from CT.
http://www.ecstuning.com/Audi-B6_A4-...arings/ES3463/
thanks
So when I go to the dealer tomorrow all I need to ask them for is a new spindle and to press a new bearing into the spindle? Are there any other bits that I need to replace with the spindle? I have all of the hardware for the control arms/shocks/tie rod ends etc...
Once I get the new spindle I will MOST GRATIFYINGLY get out the sawzall and hack that old crap off.
Fortunately the car is still drivable, it's a bit ghetto to be going around with 3 fresh bilsteins and on old shock though
