Headlight problem...
Old Feb 3, 2012 | 01:06 PM
incyder's Avatar
Default Headlight problem...
Hello all. This is my first post. Been following you guys since I bought my Audi though. Its a great information source.
Anywho, I have a 2004 A4. I recently replaced the engine(which should be a whole new thread). Everything pretty much married up alright. But weeks after, I started to experience a few electrical problems. The drivers side window wouldn't go down. After some searching, I found disconnecting the battery often fixed it. And it did.
However, weeks later, again, the other side stopped working. And this time the battery trick didn't work. I recently moved to Florida from New Jersey and three states down on my way I got pulled over by the police. He wanted to inform me I had a headlight out. By the time I got to Florida, and about 200 miles from my destination, I realized both were out. I felt like the engine had a change in power at that leg of the trip for about 5 seconds. Kinda wierd. I think it may be related.
Im taking it to the shop in a few days if an easy fix doesn't pan out here. Any help you guys might offer would be great. I'm not expecting much. I try to do my homework but I'm stumped other than to start replacing obvious swithces. If anyone knows where to access the circuit to troubleshoot out the components, I would appreciate it.
Old Feb 3, 2012 | 06:18 PM
victimdumper's Avatar
cant really voice in about the engine/headlights too much, but whenever i hear bad things about the windows not working properly its the wiring harness in between the doors (especially the drivers), i would take a look there and pull back the boot and see if they broke, if your car a a good amount of miles on it its probably falling apart in there.
also now that i think about it, my old b5 had a bunch of electric problems on it for a while, one headlight went out and then the other within the same day, turned out it was the battery somehow. i replaced it because it was dieing and everything was good after that. maybe check to see if your battery is holding charge
Old Feb 6, 2012 | 05:29 AM
lyleswk's Avatar
x2 on the door harness for your windows.
As far as the lights, I would be suspicious of the relays under the ECM box. If your cowl drains are blocked and it is raining, you maybe shorting out relays.
Old Feb 8, 2012 | 01:59 PM
incyder's Avatar
Yep, I agree about the harness. Already checked that, all clean with no marks on the wires, looked new. The drainage issue makes sense. I experienced most of the issues while it was raining. I will have to check that and get back to you...thx for the input!
Old Feb 9, 2012 | 03:30 PM
incyder's Avatar
Quick update with the info, might be non-related to the headlight issue:
After takin my car to the carwash today, and spraying it with the high powered washer, my passenger side window worked from the drivers side console. That was for about five minutes. I'm guessing maybe a loose or corroded connection someplace in one of the doors or engine bay. I'm still appreciating any input, and I will keep you posted as well for a solution. Thanks.
Old Feb 14, 2012 | 06:22 AM
lyleswk's Avatar
Take a look at the attached. Might give you some ideas.
http://www.audizine.com/forum/showth...relay+corroded
Old Feb 21, 2012 | 01:30 PM
incyder's Avatar
Thank you for the link, it was informative. I'm going to check the ground from the block to chasis. I've been installing a new stereo system in the car so the headlights have been on the back burner. I will keep everyone posted.
Grawlbain
Feb 2, 2018 11:45 AM
Grawlbain
New Member Welcome Area
Feb 2, 2018 08:33 AM
kingwoodpressurewash@gmail.com
Dec 11, 2017 07:09 AM
denver_1998_a4_1.8t
Dec 3, 2005 11:07 AM
rocketaudi
Apr 15, 2003 08:47 AM
