HELP!
Old Dec 23, 2003 | 05:47 AM
osu_a4's Avatar
New Member
Default HELP!
I went to the gas station this morning to fill up my car. My gas light just came on the night before (so my tank only had a couple gallons in it). The fuel pump kept auto stopping as if the tank was full. So I thought the pump was messed up and I drove to another gas station next door. The same thing happened and gas actually over flowed out! I didn't even put $1 in my tank yet! WTF is going on with my car???
Old Dec 23, 2003 | 06:08 AM
Carguy427's Avatar
Junior Member
Default Sounds like you have something blocking the filler neck?
Unless you can get it out or figure out what else it might be. I would take it to the dealership.
Old Dec 23, 2003 | 06:28 AM
A4sp's Avatar
Junior Member
Default Re: HELP!
It happened once to me. Just start filling very slowly and eventually you will be able to put it back on auto.
Old Dec 23, 2003 | 06:31 AM
osu_a4's Avatar
New Member
Default damn i hope i can make it that far with out running out of gas
right before christmas
Old Dec 23, 2003 | 06:32 AM
osu_a4's Avatar
New Member
wow i hope that works for me THANKS!!
Old Dec 23, 2003 | 06:42 AM
Projekt 8E's Avatar
AudiWorld Expert
it's backpressuer. Fill slowly.
Old Dec 23, 2003 | 06:48 AM
KiLLaApp's Avatar
Default that happens to me all the time, just gotta sit with it and slowly fill it, only happens when (m)
you let the car get really low on gas and continue to whip it around turns and stuff.
Old Dec 23, 2003 | 06:53 AM
teutonic blur's Avatar
New Member
Default Do you have an aftermarket exhaust system? I recall reading a post ...
...either here or in AZ about aftermarket exhaust systems rubbing against some fuel hoses and causing the exact same symptoms you describe.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 23, 2003 | 07:43 AM
osu_a4's Avatar
New Member
yeah I do - I'll check that too. I love this forum
Old Dec 23, 2003 | 07:52 AM
GrandBlancA4.dtw's Avatar
Junior Member
Default Yup...it's the pressure...
Happens to me when I let the tank get REAL low. Just use slightly depress the flap, using the nozzle, without filling the tank, and let the air pressure out. If you move in closely, you'll hear the air coming out.
