Help Mr. Wizard !
Old Aug 28, 2005 | 01:14 PM
highmileage's Avatar
New Member
Default Help Mr. Wizard !
I just bought a 98 A4 1.8T Triptronic, 90,000 miles. It needs a new timing belt, control arm (front), valve gasket cover and transmission filter and fluid change.
My question is: Is it worth buying an APR chip, and what else would be recommended while I'm doing the work ? I plan on piling the miles on, mostly highway, and it needs to be dependable and halfway comfortable.
Newbie
Old Aug 28, 2005 | 02:07 PM
Mrkrad's Avatar
Member
Default well
you'll need
brake fluid flush
trans fluid flush
coolant flush
timing belt KIT
water pump
etc etc. i'd guess you got at least $1500 (with labor) of work to do its a beotch to do the timing belt/etc on those b5's
oh your in the wrong forum. this is b6 2002+
Old Aug 29, 2005 | 02:58 PM
s4wood's Avatar
AudiWorld Expert
Default Its called Tiptronic...not Triptronic...
I would get the other work done first..see how you like the power and then consider the engine chip..and transmission chip (yes, there is one).
Carol from Canada
Jan 4, 2001 06:03 AM
JCJiffy
Sep 11, 2000 09:12 AM
Richard Gunde
Aug 12, 2000 08:03 PM
Menta
Jul 8, 1999 04:08 PM
Menta
Jul 6, 1999 12:08 PM
